Should I Replace My Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2011, 01:24 PM   #1
Should I replace my toilet?
We have this old toilet from 1980. Is there a way to convert this into a dual flush? There is no overflow pipe. Should we just get a new toilet?
http://jpegbay.com/gallery/000895675-.html#1
http://jpegbay.com/gallery/000895675-.html#2
What would you do?
mrosenb is offline   Reply With Quote
Old 03-31-2011, 01:47 PM   #2
Rewards Points: 1,494
I would leave it the way it is (assuming it still works well).
I don't know fo any conversion kits for making a dual flush with the existing toilet tank. You would have to "kit bash" aka jury rig a setup.
And there is no guarantee it would work. There is a minimum quantity of water versus how it enters the bowl needed to flush reliably. (Some bowls have a horizontal jet hole at the very bottom.) Replacing the tank with a new tank with built in dual flush setup may or may not work because the new 1.6 gallon water allotment might not flush the bowl you have.
Old 03-31-2011, 01:52 PM   #3
I was looking at something like this
http://www.gomjsi.com/
This looks like a good idea but for this to work I need an overflow tube.
Old 03-31-2011, 07:02 PM   #4
Look if you would like a dual flush toilet please buy one.
Do Not try to make it fit it never works.
You have a toilet that most would like to have back a 3.5 gallon toilet per flush.
These are hard to clog.
plumber.
twinbelle is offline   Reply With Quote
Old 03-31-2011, 09:44 PM   #5
that looks like an old mansfield toilet, the overflow is in the center of the plunger. If you want to make it a dual flush, unbolt the tank and replace the flush valve. get a standard one with a 2" flapper and you'll have your overflow. But, toilets that are designed to flush with 3+ gallons per flush will not perform as well with a 1.6 or .8 gallon flush. the liquid flush might not even create the siphon. If you're set on dual flush, go buy one meant for it... don't convert an old one
the_man is offline   Reply With Quote
Replace toilet bolts LeftOver Plumbing 7 09-21-2010 03:08 PM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
