Should I Replace The Drain And P Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2009, 04:13 AM   #1
Post
should I replace the drain and P trap
I'll be really glad if someone could help me solve my plumbing problem.The drain of my shower is leaking or something, I am thinking of replacing the drain and P trap as suggested here http://www.fixr.com/n.replace-p-trap...malden.ma.html
Do you think it's the right thing to do?
jameshow is offline   Reply With Quote
Old 04-26-2009, 08:00 AM   #2
If that is what is leaking, yes. But you need to make sure what is leaking first. If it is a shower only, the usual cause is the rubber compression washer/nut just needs to be tightened or replaced. There is usually a nut that screws in from the top and compresses the rubber o-ring tightly around the pipe. Over time that may loosen. It does not look like a nut, but may only have a couple of bumps on it. Tapping those bumps in a clockwise direction should tighten it.
Old 04-26-2009, 10:32 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
If it is the rubber compression ring, an easy way to tighten it is to take two large screw drivers and place the tips aginst the detents on the ring in an "X" to leverage against each other and turn the nut clockwise. I also like to add a little silicone when done to help seal and make the water run down the drain, rather than rest on the ring/pvc.
Man of many hats
wrangler is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 08:08 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
Replace tub's drain ring without removing tub? BradG Plumbing 12 03-17-2009 12:21 PM
Replace Drain Field? namderd Plumbing 1 04-20-2008 08:59 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
