Should I Pex (3/8" Copper Tubing) - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2012, 03:18 PM   #1
Rewards Points: 264
Should I pex (3/8" copper tubing)
I'm fixing up a trailer that currently has 3/8" copper tubing with compression fittings, or at least 'partially has', because I ripped out %60 of them, the bathroom and the old hot water tank.
Part of me loves 1/2" copper and wants to solder a brass fitting to the 3/8" and do it all in copper pipe, but I'm thinking the best approach is to use a shark-bite fitting, then buy a Pex band tool off ebay and do everything in 3/8" Pex (probably with Sharkbites at the hot water tank)
Does this seem like the best way? Part of the reason I like this approach is because I want the pipes hidden, and they'll be damn hard to solder up in the ceiling. Price is probably about the same - pipe is dirt cheap but I'll need a tool and bands and super-expensive Sharkbite fittings. Sharkbite looks a little quicker too, even though I'm pretty proud of my current soldering skills.
tibberous is offline   Reply With Quote
Old 12-02-2012, 05:47 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Use crimp ring fittings and upsize to 1/2" PEX. Use 3/4" feeders off WH.
Coastal South Carolina
Old 12-02-2012, 06:50 PM   #3
Rewards Points: 13,748
3/8 will give you very little flow, forget the shark bites for this job.
Old 12-02-2012, 08:53 PM   #4
Rewards Points: 264
Problem is that its 3/8 literally to the well, and the trailer is on top of the well =/
If you go 1/2" from 3/8" does it help water flow? I could do everything in 1/2" and if the water ended up being really bad, have someone come out and replace the well line and possibly pump.
The other weird thing is that there doesnt look to be a wellxtrol pressure tank.
Old 12-03-2012, 07:56 AM   #5
This is making less and less since.
Old 12-03-2012, 10:26 AM   #6
Rewards Points: 264
That's how they did it though: 3/8" tubing goes under the kitchen sink, down into the ground. It runs from the kitchen sink, back to the hot water tank, then into the bathroom, then back out to the kitchen.
Old 12-03-2012, 12:13 PM   #7
Special User
Rewards Points: 1,230
Yes, it does.
If it were me, I'd run 3/4" to at least the water heater and shower because I hate weak showers. Unless you're just flipping this trailer, the incremental cost going from 1/2" Pex to 3/4" for that part of the system isn't huge.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Copper Pipe vs Copper Coil Tubing For Refrigerator Water Line kaalapurushha Plumbing 3 10-15-2012 08:59 PM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 06:47 PM
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 02:23 PM
I need advice on a home project it involves PVC and copper tubing please help Mufasa02 Off Topic 8 08-16-2011 06:08 PM
Buried Copper LP Tubing Earnie Plumbing 1 02-22-2011 08:22 PM
