-   -   Should I pex (3/8" copper tubing) (http://www.diychatroom.com/f7/should-i-pex-3-8-copper-tubing-165391/)
tibberous 12-02-2012 03:18 PM
I'm fixing up a trailer that currently has 3/8" copper tubing with compression fittings, or at least 'partially has', because I ripped out %60 of them, the bathroom and the old hot water tank.
Part of me loves 1/2" copper and wants to solder a brass fitting to the 3/8" and do it all in copper pipe, but I'm thinking the best approach is to use a shark-bite fitting, then buy a Pex band tool off ebay and do everything in 3/8" Pex (probably with Sharkbites at the hot water tank)
Does this seem like the best way? Part of the reason I like this approach is because I want the pipes hidden, and they'll be damn hard to solder up in the ceiling. Price is probably about the same - pipe is dirt cheap but I'll need a tool and bands and super-expensive Sharkbite fittings. Sharkbite looks a little quicker too, even though I'm pretty proud of my current soldering skills.
rjniles 12-02-2012 05:47 PM
Use crimp ring fittings and upsize to 1/2" PEX. Use 3/4" feeders off WH.
joecaption 12-02-2012 06:50 PM
3/8 will give you very little flow, forget the shark bites for this job.
tibberous 12-02-2012 08:53 PM
Problem is that its 3/8 literally to the well, and the trailer is on top of the well =/
If you go 1/2" from 3/8" does it help water flow? I could do everything in 1/2" and if the water ended up being really bad, have someone come out and replace the well line and possibly pump.
The other weird thing is that there doesnt look to be a wellxtrol pressure tank.
joecaption 12-03-2012 07:56 AM
This is making less and less since.
tibberous 12-03-2012 10:26 AM
That's how they did it though: 3/8" tubing goes under the kitchen sink, down into the ground. It runs from the kitchen sink, back to the hot water tank, then into the bathroom, then back out to the kitchen.
tylernt 12-03-2012 12:13 PM
Yes, it does.
If it were me, I'd run 3/4" to at least the water heater and shower because I hate weak showers. Unless you're just flipping this trailer, the incremental cost going from 1/2" Pex to 3/4" for that part of the system isn't huge.
