Should I Leave Space Between Toilet Flange And Subfloor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2010, 01:25 AM   #1
Should I leave space between toilet flange and subfloor?
Hi I have a question about toilet flange.
During bathroom rough in, should I leave space between toilet flange and subfloor for tiles and thinset in the future?
I am afraid if I weld the flange to the closet elbow now, I won't be able to install tiles in the future. That would be a stupid mistake.
Please give me some advice. Thanks!!!
pttcc is offline   Reply With Quote
Old 09-07-2010, 08:27 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A toilet flange should be bolted ON TOP OF THE FINISHED FLOOR LEVEL, and then the toilet bolted to the flange. If it is any lower, the wax ring likely won't seal properly.
I just had one of my real estate clients pay $3,200 to repair a half-bath floor and a large part of her living room/dining room flooring due to some nitwit installing the half-bath toilet flange on the sub-floor level. When the repair contractor took it all apart, he found that the wax ring hadn't even come into contact with the toilet and it had been leaking since Day One more than 6 months before.
Mike
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
pttcc (09-16-2010)
Old 09-07-2010, 08:30 AM   #3
unless its linoleum, then yes. take a piece of the finish floor and slide the flange down over it. If you're tiling, then use a tile and piece of cardboard to account for mortar. if its linoleum, the difference is too slight to worry about. make sure that flange is secured properly to the flooring when you're done other option is to wait until you do the finish floor, cut the pipe flush w/ the floor and glue it on last
the_man is offline   Reply With Quote
The Following 2 Users Say Thank You to the_man For This Useful Post:
braindead (09-08-2010), pttcc (09-16-2010)
Old 09-07-2010, 08:44 AM   #4
The flange should be secured to the final flooring, using the holes in the flange for screws. No gaps or filling in with anything. In cases where a new floor material is added to an existing room, an extender flange should be used to acquire the additional height needed to bring the surface up to proper level.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
pttcc (09-16-2010)
Old 09-07-2010, 09:35 AM   #5
Rewards Points: 558
Iím not an expert plumber but all the toilets I have removed all had the flange sitting flush with the finished floor.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
pttcc (09-16-2010)
Old 09-07-2010, 09:58 AM   #6
If I don't glue the flange to the sewer pipe right now, is there any way I can still pass the plumbing rough inspection?
Old 09-07-2010, 11:05 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 566
Yes, he should sign off. Simply put a test cap on the 3" stub that extends thru the floor.
The Following User Says Thank You to TheEplumber For This Useful Post:
pttcc (09-16-2010)
Old 09-07-2010, 01:42 PM   #8
Yes. The flange is not required for the inspection. The testing is for leaks.
pttcc (09-16-2010)
Old 09-08-2010, 08:36 PM   #9
If you do wait to install the flange, make sure there is enough gap around the pipe to slip the flange down after the finish floor is installed
The Following User Says Thank You to the_man For This Useful Post:
pttcc (09-16-2010)
Tags
toilet flange
estimating flange height for rear outlet toilet JakAHearts Plumbing 6 07-04-2010 04:53 PM
Toilet flange question. speedster1 Plumbing 4 04-07-2010 10:30 AM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 07:40 PM
Subfloor & toilet flange MichaelWayne_71 Flooring 5 11-06-2007 06:28 AM
