Should I Install Water Pressure Regulator... - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2009, 09:13 PM   #1
Rewards Points: 77
should I install water pressure regulator...
My pressure at utility sink, in the basement is just under 85psi. If I need a regulator can I install it on vertical pipe above water meter, or should I install it on a horizontal pipe? Are the regulators compression or sweat on?
Thanks in advance for any sugestions.
dbldee20 is offline   Reply With Quote
Old 07-15-2009, 09:17 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
If the pressure is 85 at the utility sink then I would think the whole house is at 85 psi
I would install a regulator to reduce the pressure
It does not matter if it is verticle or horz just install it where the water service enters the house.
Old 07-15-2009, 09:41 PM   #3
as stated before you can install in right after the water meter in the house and it can be vertical or horizontal. they will have female threads on them so you will need to sweat on male adaptors assuming you have copper piping.
plumber Jim is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 09:18 AM
