Should I Get A New Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2011, 06:19 AM   #16
raylo32's Avatar
Rewards Points: 1,244
Looks nice! I really need to get a new water heater as mine has always been horrible at keeping a consistent temp and is 16 years old. Not as old as yours was but pretty good for modern stuff that doesn't seem to last like they used to.
I actually flush mine from the drain valve with a garden hose using the air pressure fed into the tee. My tee is on the cold side so that the air coming in will stir up the sediment but really don't think it matters all that much which side. I blow it totally dry through the hose on the drain valve into a nearby utility sink.
raylo32 is offline   Reply With Quote
Old 10-31-2011, 08:17 PM   #17
Rewards Points: 77
How do you know flushing is actually helping? Do you see solid particles coming out? How often do you flush it out?
vcheez is offline   Reply With Quote
Old 11-01-2011, 01:47 PM   #18
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Originally Posted by raleighthings View Post
Of course you have to have room to put one of these into the top of the tank.
I think I saw one on This Old House or similar years ago that was made like a chain with long links to allow you do insert it when you only have a couple of feet clear above the tank.
Anyone know where to buy these? My Google Foo didn't find any.
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/Flexible-HexHead-Magnesium-Anode.html
Oh-Fudge is offline   Reply With Quote
Old 11-01-2011, 03:25 PM   #19
Limited Experience
raleighthings is offline   Reply With Quote
Old 11-15-2011, 07:02 PM   #20
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I enjoyed reading this as my water heater was manufactured in 1969.
I have a funny feeling the drain will be non-functioning on it as well and should probably start considering a replacement.
CoconutPete is offline   Reply With Quote
Old 11-15-2011, 07:25 PM   #21
raylo32's Avatar
Wow, 1969... you've got your $'s worth out of that one! I installed my own new water heater this past weekend. Much more efficient than the old one and with the electronic controls much better temp regulation. I decided not to install a permanent tee for connecting an air compressor for periodic flushing since I used flexible water connectors. Easy enough to just disconnect one and connect up the air line when I need to.
Old 11-16-2011, 10:41 AM   #22
raylo32's Avatar
When I took my old WH to the dump some of the gunk came out in my truck bed. The tank was laying down and the gunk flowed out of the open water connection nipples. It looks like a cloudy gel with white mineral flecks. Not sure there is a definite way to measure if flushing helps or not but it makes sense that it does. The gunk probably hurts heat transfer from the burner to the water and perhaps coats the thermostat if it gets deep enough. I can't say what it looks like while flushing because the hose end is down in a drain pipe but I bet if you flushed it to a sink you'd see cloudy water.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
