Should I Call A Plumber? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2009, 10:19 PM   #1
Should I call a plumber?
I'm having an issue in my master bathroom. When I drain the water from my tub, my toilet water bubbles and makes a weird noise and water comes up out of my shower drain. My toilet also bubbles and makes the same weird noise when I run the sink water as well. I don't have any issues with any other bathrooms in my house. Should I call a plumber or is this an easy fix?
tarch is offline   Reply With Quote
Old 12-17-2009, 01:59 AM   #2
duh who me
El Cheapo's Avatar
Thumbs up
bubbling
If it is just the one bath room ,the stoppage is between the bathroom and the stack.If your good with tools talk to a rental company, explain problem he might hook you up with right tool.Some newer homes have cleanouts in the bathrooms or closets in hall near the bath room affected, a good machine with at least 25 ft of cable should get it open. If you dont understand what i am talking about ,call a plumber
El Cheapo is offline   Reply With Quote
Old 12-17-2009, 12:26 PM   #3
thanks
Old 12-17-2009, 02:48 PM   #4
union journeymem plumber
130 plumber's Avatar
better yet,whens the last time you had your sewer rodded out?sounds like your sanitary sewer line clog.
And yes call a plumber to rod out the line
130 plumber is offline   Reply With Quote
Old 12-17-2009, 02:51 PM   #5
ALso do you have a overhead sewer system,crawl space or slab?
Old 12-17-2009, 04:19 PM   #6
we purchased this house about a year ago, it was built in 2001 and it was bank owned. So i have no idea when the last time the sewer was rodded out(I have no clue what rodded out is) or if it has a overhead sewer system,crawl space or slab, I just don't want to pay someone if I can do it myself. Now if the problem is above my head, I have no problem paying a plumber
Licensed Plumber ? lrm17 Plumbing 3 03-02-2009 02:33 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
