Should A Diy Be Able To Install A Gas Stove? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2012, 03:38 PM   #1
Rewards Points: 1,062
should a diy be able to install a gas stove?
People,
Another project for our new home coming up- installing a new gas stove/cooktop. The appliance company will deliver the stove, but will not instal the gas line . Isnt that a flex brass tube, about 3' long?
Is that an easy job? Do I need teflon tape, or plumbers putty/cement of some sort as well?
Thanks!!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-22-2012, 06:50 PM   #2
Rewards Points: 13,748
Is there already gas supply line there behind the stove with a shut off?
Scares me when you ask the questions your asking. It's all done with flared fittings on the flx lines with nothing on the fittings where it attaches. Any pipe threads for the adaptors can be teflon pipe dope or yellow gas line tape.
Old 03-23-2012, 07:04 AM   #3
What Joe said. Most localities don't like homeowners doing their own gas line work, but it can be a DIY job It should be inspected!! If the gas line is there already, as he said, it must have a shutoff valve behind the range, then a flex coupling is OK in most localities.
If there is not gas line at the range location, consider a call to your local plumber.
Old 03-23-2012, 07:51 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Towns in my region require a gas permit with an antitilt mechanism - on new gas stove installs.
Just had to pull one last month on a renovation project that included the Kitchen.
- Build Well -
Old 03-23-2012, 09:05 PM   #5
Rewards Points: 582
Originally Posted by noquacks View Post
People,
Thanks!!
I commend you for your ability..but In the case of gas line work in most places as was mentioned this should be left to the pro with full experience, not to mention you may need a permit and be certified...
Old 03-24-2012, 08:39 AM   #6
Rewards Points: 672
I THINK...
I think everyone here should have a DIY number based on past jobs accomplished successfully. Then all jobs should be assigned a DIY number, for instance, changing a shut off valve under the bathroom sink should be a 1.5 DIY and building an entire house would be a 10.
Then if someone was thinking of taking on a new job, they should never tackle a job that is more than 1 or 2 points above their current DIY score without the assistance of either a professional who specializes in the job or a DIYer with a higher number.
There, I did all the hard, conceptual work. I will let you guys flesh out the rest. Oh, and don't forget to call it the Beepster Scale.
I think I am around a 6-7 DIY Number. What is your DIY Number? (not to highjack the thread).
B
Beepster is offline   Reply With Quote
Replacing Electric stove w/ gas stove PMV Appliances 3 01-02-2012 02:00 AM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 09:02 AM
Gas Stove Install johnrh Plumbing 3 04-07-2010 06:36 PM
Gas Stove installation MikeCT01 HVAC 0 12-08-2009 10:50 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
