Short Supply Of How Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2007, 02:42 PM   #1
Rewards Points: 1,062
Question
short supply of how water
hello gurus,
the problem this time is that hot water runs out really fast, after about 5 min. the water heater is 40 gal and gas and the only other appliance that shares gas is the furnace for radiators. i am not sure about the size of my gas meter but the line that connects it with the two appliances is 3/4 in.
could it be because most of the gas that comes in gets absorbed by the furnace so not much goes to the water heater ?
this has been happening only since recently, i.e. since it's been cold.
thanks,
- a
Old 12-14-2007, 02:45 PM   #2
Eibwen
Could be the tank is just going bad and your noticing it because its getting colder.
Any idea how old it its?
Sammy is offline   Reply With Quote
Old 12-14-2007, 03:56 PM   #3
Send a message via AIM to Marlin
As was already asked, how old is your water heater?
Has it always been this way?
It's really hard to say without knowing what size furnace you have, the length of the run, and how many BTUs the water heater if is 3/4 is the correct size. I highly doubt that is your problem though. If you really want to test it just for piece of mind:
Make sure your water heater isn't running (to be sure it's up to temperature).
Turn the switch to your furnace off (so it won't run while you do the next step)
Take a shower and time how long your water lasts, don't just estimate.
I pulled the flow restricters out of my shower heads and if I let the hot water run full blast my 40 gallon tank (which is really about 36) will be empty in ten minutes. So it is possible you're just emptying the tank.
If it still doesn't work out you could try flushing the water heater.
Marlin is offline   Reply With Quote
Old 12-14-2007, 05:26 PM   #4
Sounds like the water heater has sediment in the bottom of it.
It is a good idea to drain the hot water once a year to remove the sediment.
are you on public water or a well?
redline is offline   Reply With Quote
Old 12-14-2007, 08:50 PM   #5
public water.
Old 12-14-2007, 10:09 PM   #6
Journeyman Plumber
Ron The Plumber's Avatar
Check the dip tube, could be broken.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-15-2007, 02:32 AM   #7
Master Plumber
Rewards Points: 150
Right answer. Dip tube can be replaced by unscrewing the cold side nipple or most of the time best just to replace the water heater if it is anywhere near ten years old and be done with it.
jpplumber is offline   Reply With Quote
Old 12-15-2007, 07:03 PM   #8
Question
thanks everyone. could someone give more detail as to where i look for things like "cold side nipple" or "dip tube"? i am somewhat unfamiliar with the structure of a gas water heater.
also, i noticed that my water heater has no connection to electric power, which go me wondering how the embedded thermometer/thermostat works, or simply the apparatus that determines when it needs to fire it off to heat more water. this is outside of the domain of the problem, i.e. simply my curiosity to learn more how these things work.
if there is an online exhibit or something that breaks down a water heater like this, that would be great.
Old 12-15-2007, 09:55 PM   #9
http://home.howstuffworks.com/water-heater1.htm
Washing machine - hot water supply only? Sosh Plumbing 4 07-11-2007 03:36 PM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 08:51 AM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 01:22 AM
