Short Sink Drain Stopper - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2010, 01:30 AM   #1
I installed a MasterBath brand sink. It is a molded sink with an extension added to the drain to accommodate the sink overflow hose. This extension makes the distance that the drain stopper needs to go to the pivot rod about a 1/2 inch longer. How can I extend the drain stop?
conklinw is offline   Reply With Quote
Old 08-16-2010, 07:08 AM   #2
Not sure I understand the problem. Most rods and such are plenty long for any type sink.
Old 08-16-2010, 08:50 AM   #3
Since the overflow drain is not molded into the sink they used a hose that connects to an 1 1/2 inch extension on the bottom of the sink. This doesn''t allow you to tighten the drain as much as usual an leaves the rod lower. Therefore, the drain stop doesn't reach the rod. The bottom of the stopper will touch the rod but it is not long enough for the rod to fit into the stopper ring.
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 09:23 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 01:14 PM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 10:52 AM
Maximum distance of sink from drain? DIYHomeTheater Plumbing 0 06-14-2010 08:42 PM
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 11:56 AM
