Shop Vac - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2011, 03:42 PM   #1
Shop Vac
We had a tonne of snow this winter and I am expecting to get some water in my basement this spring. Instead of using my shopvac and dumping it everytime it fills, is there a way to set it up so that the water goes directly from the shopvac to my sump pit or sewage drain or even by laundry sink?
Nugget is offline   Reply With Quote
Old 03-30-2011, 04:35 PM   #2
Homerepairguy's Avatar
Rewards Points: 990
I would say no since the suction depends on the tank being air tight except for the input hose. Also, when dealing with electricity and water, I think the danger factor is just too high to risk any self made mods.
I would just buy a proper water pump.
HRG
Homerepairguy is offline   Reply With Quote
Old 03-30-2011, 07:12 PM   #3
Rewards Points: 1,088
Yes, this is possible.
Using your drain port on the bottom of the shop vac, you can jimmy up some sort of drain pipe with a garden hose and let that flow out to your sump pit.
Or, go get another Shop Vac that has the pump feature.
http://www.shopvac.com/wet-dry-vacs/...cSKU=960-10-00
handy man88 is offline   Reply With Quote
Old 03-31-2011, 07:29 AM   #4
Just a thought, but if you would expend as much energy getting surface water away from the house, you might not need that shop vac. Proper grading and working gutters will solve 90% of basement water problems. if you have a high water table, forget what I said, work on the vac rig.
Old 03-31-2011, 09:34 AM   #5
PAO
believe Sears brand shop vacs have a pump attachment available as well to connect external to the drain port....
PAO is offline   Reply With Quote
Installing a furnace in my shop pdwoods55 HVAC 3 11-16-2010 06:03 PM
Wiring Shop Scrubbie Electrical 6 03-09-2010 07:23 PM
Sub-panel selewis Electrical 23 02-21-2010 11:52 PM
Wiring shop need advice stqevo Electrical 14 09-03-2009 01:18 PM
Sizing wire/breaker to new shop. Roy Rowlett Electrical 8 04-22-2009 01:29 PM
