Old 01-29-2009, 10:07 AM   #1
RDS
Shimming a tub
I gutted my bathroom and had plumbers install a new cast iron tub in an alcove. After they left, I noticed they'd levelled it by placing wooden shims under the skirt of the tub, not the feet.
This seems wrong to me on two levels. First, wood shims may crack/soften over time. Second, the ends of the shims protruding into the room will interfere with the flooring I'm going to put down. And anyway, the install instructions that came with the tub explicitly say to only use metal shims, and only under the feet.
(The front feet, i.e. the two nearest the drain, are actually right on the subfloor, but the back two are hovering about 3/8" off the subfloor. That's where I want to add metal shims.)
I could call the plumbers back but I'd rather just fix it myself rather than wait for them. But where do I get metal shims? Neither of the big home stores carries them, and even searching on line, all I find are washer-style shims (too small) and super-super-thin shim stock for industrial applications. The picture in the tub install guide shows what look like maybe 3"x5" rectangles.
So I guess I'm asking (a) Am I being too anal, and wooden shims under the feet would be fine, and (b) If I do need metal shims, where does one get them?
RDS is offline   Reply With Quote
Old 01-29-2009, 10:16 AM   #2
Shimming a tub
You could probably use some squares of plywood.
jerryh3 is offline   Reply With Quote
Old 01-29-2009, 11:06 AM   #3
Shimming a tub
Could you get a phenolic or metal sheet and make your own? You could combine shims to get the right height
47_47 is offline   Reply With Quote
Old 01-29-2009, 11:56 AM   #4
RDS
Shimming a tub
I thought about that. I don't really have the tools to cut a metal sheet of any thickness, though. Although I suppose I could take something really lightweight like an old aluminim gutter and use snips to cut a few squares and stack 'em.
Was hoping for something less laborious (and fewer sharp edges) but in a pinch I could do this I suppose.
Old 01-29-2009, 12:04 PM   #5
Remodeling Contractor
Shimming a tub
You can buy composite shims as well as plastic shims. I would use the plastic shims in this case. Will not compress like the metal ones, impervious to water damage and can be trimmed for the flooring.
Old 01-29-2009, 06:42 PM   #6
Shimming a tub
+1 on the plastic shims with construction adhesive.
II Weeks is offline   Reply With Quote
Old 01-30-2009, 08:28 AM   #7
RDS
Shimming a tub
OK, I found some heavy-duty plastic shims on-line and will use those. Thanks everyone.
More On This Topic
There are many options when it comes to choosing a swing set. Wooden or metal are just two of the options from which you have to choose for a complete play system for your backyard. There are many different designs to fit every space, so to narrow down... Read More »
Today we have installed a new faucet on an older sink, which we’re going to put in our new kitchen remodel. What we’re doing is we’re just going to connect the supply hoses, which can be one standard size, but they’re not. Just... Read More »
Hello I'm Annie Brunson on behalf of Expert Village. Today we are going to learn how to make a one string base. What you will need for this is some kind of tub I have a very large oatmeal tub here. I'm using two old fashion cloths pins but really... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Again, you've got to make sure that the box is installed properly. Make sure that it is on a wooden support or a metal bracket up above... Read More »
You're thinking of replacing those old, worn out sliding shower doors with a new pivot-type of shower doors. There are lots of things to consider while selecting the right type of shower doors for your shower. Here's how to buy the right type of shower... Read More »
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 08:48 PM
Shimming Floor Joists? cbeingessner Building & Construction 7 09-25-2007 08:47 AM
Shimming Trimmers to Pass Framing Inspection? Ricky D Building & Construction 6 06-03-2007 10:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
