Shimming Toilet?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2012, 04:02 PM   #16
Rewards Points: 2,516
Originally Posted by Jay 78 View Post
I don't know exactly what the pros do, but I left a few inches uncaulked at the back that can't be seen.
I agree. leave the rear of the toilet uncaulked.
hammerlane is offline   Reply With Quote
Old 05-01-2012, 05:23 PM   #17
Shimming Toilet
I don't recommend coins to shim a toilet. Toilets are made of porcelain china - so they can crack. And just setting a toilet directly onto the floor is fine - as long as your floor isn't made of tile, is level and is the correct height. If a tile floor comes into contact with the porcelain, damage to the tile floor and/or toilet can result. Personally, I like the Johnny Shims.
Dave Holland is offline   Reply With Quote
Old 05-01-2012, 07:59 PM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What?!
Journeyman Plumber
Old 05-02-2012, 06:28 AM   #19
Rewards Points: 1,500
It should have been test fitted without the wax ring and before the bolts are tightened. Any rocking should have been corrected then. Do not expect the bolts to prevent or correct rocking, that will break something instead
Old 05-02-2012, 06:54 AM   #20
Rewards Points: 338
Things I have used for shims -
Old Credit Cards
Plastic Business cards
A piece of self stick floor tile - it can be shaved or peeled.
tribe_fan is offline   Reply With Quote
Old 05-02-2012, 09:16 PM   #21
Just a DIY guy
Originally Posted by Alan View Post
What?!
I hope he's wrong, or my newly tiled bathroom is doomed!
M3 Pete is offline   Reply With Quote
Old 05-02-2012, 10:16 PM   #22
Doing it myself
Alan's Avatar
I've pulled countless dozens of toilets 20+ years old off of tile that don't have damaged porcelain.
Journeyman Plumber
Old 05-09-2012, 03:17 PM   #23
Shimming Toilet & Tile Floors
I'm simply saying - so far Johnny Shims are the best product I've seen for toilet installations. I work for a property management company with over 3,000 unique properties; apartment buildings, condos, private homes and commercial.
Porcelain toilet coming into direct contact with porcelain tile, isn't really ideal in my opinion. Doesn't mean it can't be done, or that it's guaranteed going to crack. All the plumbers I know, simply throw away those squishy little square shims that have been around for so long, because they compress and can work their way out.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Shimming a toilet handy man88 Plumbing 5 08-02-2009 07:49 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
