Sharkbites On Copper? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2014, 04:29 PM   #1
Electrical Enthusiast
Rewards Points: 504
Sharkbites on copper?
We have a hunting cabin (about 30 years old) with a detached laundry room plumbed with 1/2" copper pipe. There is a cold water line sticking out of the wall where I think a water heater used to be. We had record cold temperatures (around zero) recently and this line froze and broke the solder joint causing a small but steady leak. I bought some new end stops to try and cut and redo the joint. For some reason I simply could not get the pipe to fit in the stop, even after deburring and sanding with fine sandpaper. I ended up sticking a shark bite end stop on it. It's not leaking currently, but can I trust it? Thanks.
Kyle_in_rure is offline   Reply With Quote
Old 01-19-2014, 04:35 PM   #2
Rewards Points: 13,250
Should be fine.
Most likely the pipe swelled when it froze.
Old 01-19-2014, 04:45 PM   #3
Rewards Points: 504
Originally Posted by joecaption
Should be fine. Most likely the pipe swelled when it froze.
That's what I was thinking. I tried the shark bite first and it started dripping then shot off like a bullet but after the sanding it seems alright.
Transition from 3/4" rigid copper to 3/4 soft copper TVC15 Plumbing 2 10-05-2012 06:30 AM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 05:14 PM
copper clad aluminum CopperClad Electrical 45 06-23-2012 04:21 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
