Sharkbite/PEX Vs. Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 03:13 PM   #1
Sharkbite/PEX vs. Pipe
Whats a more reliable 1/2" residential water fitting? sharkbite and pex, or a threaded pipe fitting?
mopowers is offline   Reply With Quote
Old 01-18-2013, 03:22 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 602
Ayuh,.... It depends on what yer attachin' to whatever else...
in other words, with yer Few words, yer question is Unanswerable...
Bondo is online now   Reply With Quote
Old 01-18-2013, 03:30 PM   #3
Which joint is less likely to leak? Assuming both joint are attached correctly and clamped sturdy in a wall?
Old 01-18-2013, 05:20 PM   #4
Rewards Points: 13,266
All will work if done correctly. Really would be great if we had all the info on exactly what it is your trying to do.
Old 01-18-2013, 06:47 PM   #5
I had a brass 90 split from cold weather on an exterior wall where an outside hose bib comes in. The 90 is connected to pex with a crimp that travel up the stud bay. I cut the pex above the 90 to cap it so I can use my water until I fix the plumbing. I'm just trying to figure out what the best fix is, that's all. Seems like there is 100 different ways to fix it. If a pipe connection is more leakproof than a sharkbite, I'll minimize the sharkbite connections I use, etc...
Old 01-18-2013, 08:04 PM   #6
Bondo's Avatar
Rewards Points: 602
Ayuh,.... The problem is gonna be, No matter what fittings you use, when Frozen, they Split....
Old 01-18-2013, 08:21 PM   #7
pro handyman's Avatar
Any fitting you use will work. But you have to insulate that area so it won't freeze and bust again.
pro handyman is offline   Reply With Quote
Old 01-18-2013, 08:32 PM   #8
Rewards Points: 4,792
PEX is probably less susceptible to bursting from freezing, since it has some expansion capability. A crimped on connection is normally used for PEX. But Sharkbite-type connectors are allowed behind walls by most codes so use it if you want to. They are more expensive than the crimp rings, but then if you don't have a crimper that can get more expensive.
jeffnc is offline   Reply With Quote
Old 01-18-2013, 09:03 PM   #9
Freezing is not a concern for me. This was the only hose bib that I hadn't insulated. We're in a little bit of a cold spell here in CA. I'm just wondering which joint is better (ie. more leak proof). Either one will not freeze because it will be insulated.
Old 01-18-2013, 09:08 PM   #10
I've seen both leak, but I've never seen either leak if it's installed properly. So I guess the question is which is harder to install properly. You have to verify the Sharkbite is in all the way, but there is a known distance it should go in so you can verify that. I don't know how to verify threaded pipe.
Old 01-18-2013, 09:08 PM   #11
Rewards Points: 582
which one do you like..that is the best one for you ......ben sr
Old 01-18-2013, 09:11 PM   #12
I like crimped on PEX connections. After that I like Sharkbite connections.
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 03:46 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
