Sharkbite Fittings On PB Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2011, 01:02 PM   #16
The thing that bothers me is the ccsst gas pipe uses a rubber o ring for the seal in the couplings just like shark bites.
WDR is offline   Reply With Quote
Old 07-22-2011, 03:01 PM   #17
There is a special shark bite coupling now that is made to hook onto Poly B now, when you look at it one side has the plastic parts are grey colored. Regular shark bites will work but they are not approved as previously stated.
As to gas lines safety for you and your family is rule #1 might be best to let a professional deal with it, he has liability insurance and trained to properly deal with it.
Adam_M is offline   Reply With Quote
The Following User Says Thank You to Adam_M For This Useful Post:
VIPlumber (07-22-2011)
Old 08-16-2011, 01:33 PM   #18
Rewards Points: 14
Sharkbite fittings
When a plumber visited my home, recently, and saw that I had used Sharkbit fitting to connect my PB plumbing to my laudry single lever shutoff valve, he made the comment,"Oh, we don't like them." I asked him why he said that. He said, "Because, if everyone used them, we might be out of business."
VERY EASY to install! Works great and I don't anticipate any problems. Since I missed the class action suit before it closed, I have one eye open to it being re-opened. In the mean time, my mind is at ease, knowing that, should the need arrise, I may not even need the services of someone who charges so much to replace a fitting or a valve! Three cheers for Sharkbite! I hope the inventor is a millionaire.
papernpaste is offline   Reply With Quote
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 08:39 PM
SharkBite fittings... cgerikh Plumbing 12 05-21-2008 01:04 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
iron pipe fittings Talman48 Plumbing 2 01-10-2007 05:11 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
