Sharkbite Fittings?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2010, 06:42 AM   #1
sharkbite fittings??
As a remodeler, I have done a lot of plumbing with soldered fittings over the years. I watched, with interest, the new sharkbite fitting s and have always been skeptical of them. Never tried them, but Rich on "this Old House" likes them, and most plumbing codes accept them, even inside walls. BIL had a leak inside a wall last week, I used two sharkbites at the elbows in the basement. One leaks. 50% of those fittings I have used leaks, not much of a recommendation.
Old 02-14-2010, 09:16 AM   #2
Remodeling Contractor
you must have installed them wrong. I have used 100's of them and never saw a leak yet. Maybe using them for 4 years now.
Old 02-14-2010, 09:30 AM   #3
Licensed Master Plumber
we use them for temporary repair and testing only. I would never rely on one of them, especially in a concealed location. After all, it's just a piece of pipe with a couple o rings and a ss barb in it. You can ask yourself why they are approved and accepted and the answer is going to be because the manufacturers have lobbied the code review boards quite successfully. Big question though. What would you have used 20 years ago? And finally, do you really need to save that extra 10 minutes that soldering it would take?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-14-2010, 06:00 PM   #4
It was a tight spot up in the floor joists, too much combustibles, so i thought I would give them a try. I have soldered for 25 yrs, why change now.
Old 02-14-2010, 06:46 PM   #5
i'm with bob if used/installed correctly i think they are a real plus particulrly in real tight spots
The older I get the better I was
Old 02-15-2010, 02:04 PM   #6
Rewards Points: 264
Used a T in a tight spot between joists, couldn't get a DIY'er torch in there, and its fine. Both valves on my water meter are shot and we could only shut the water off 90%. Cut the pipe quickly and threw on a ball valve sharkbite on the main line. $30 valve and a little water to clean up but man was that easier and faster than having to shut off water at the street. I must have checked that fitting 3 times a day for a couple weeks before I finally had faith in it... that was over a year ago.
moneymgmt is offline   Reply With Quote
Old 02-16-2010, 05:57 AM   #7
Red face................went back to check on the problem yesterday, pipe was not fully seated in the fitting. Pushed it up tight and all seems fine now. And I just told you how experienced I was.
Old 02-16-2010, 06:10 AM   #8
Just as an aside. In the first post you said you were a remodeler and have done a lot of plumbing over the years. Don't you have to be licensed to do that for profit? I'm not trying to start a big argument here either. It's just that, if you do unlicensed plumbing and get paid for it, and if there is a problem in the future, the lawyers are going to eat you for lunch. No problem doing it in your own home but it could really come back and bite you on the butt if you do it for profit.
Old 02-16-2010, 07:48 AM   #9
who's making proffits?
Old 02-16-2010, 08:05 AM   #10
Military Mom of 4
Snav's Avatar
The people who make sharkbites are, that's for sure. :D They aint cheap!
Sharkbites are great - I love them. They are a bit touchy, as you discovered - you MUST ensure the end of your cuts are flush, snarl free and squared. You need to insert the pipe with a steady twisting pressure - I've often found that the pipe needs to go in further than you think and sometimes it takes effort to get it there. (Obviously this was the case with you - I've done it, too )
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-16-2010, 08:33 AM   #11
These days it would seem Exxon Mobile, and several big bank CEO's
Old 02-19-2010, 01:23 PM   #12
I'm pretty sure he meant that HE wasn't making any profits!
Pumpguy is offline   Reply With Quote
Old 12-31-2010, 09:04 AM   #13
SharkBite Fitting Follow Up
I know "how" to solder. But, like many things, there is an acquired skill level. And I just don't do it often enough to be good at it. I had to cap a 3/4" water pipe and used a SharkBite end cap. It was easy but I just didn't have faith in it. Like a previous responder, I checked it hourly for days, even getting up in the middle of the night in a panic. Not a drop of leakage. I added a humidifier to my furnace and used a SharkBite T, a ball valve and a reducer. Took me all of ten minutes with no leaks and it looks good.
This type of fitting has been used for years in high-pressure hydraulic lines. The science is good. And after a year of use with no leaks, I am convinced they fit the bill for DIY use.
Cotuit329 is offline   Reply With Quote
Old 12-31-2010, 07:29 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 684
This sounds kinda like the qest pipe argument
The Following User Says Thank You to TheEplumber For This Useful Post:
Plumber26 (01-01-2011)
Old 01-01-2011, 07:50 PM   #15
Picky Plumber
Yeah, Quest pipe was the best thing since sliced bread.... until it wasn't! Sharkbites are great for temporary repairs, and they are easy fix for DIY'ers. I only keep 2 3/4'' caps and 2 1/2'' caps in my truck. If I get a call @ 2am, they'll be used until I can return the next day to do a permanent fix. Copper soldier joint is the only connection that has stood the test of time IMO. But, even then it depends on water quality, the person doing the work, and what type of pipe is currently there. But, it's only my opinion.
Plumber26 is offline   Reply With Quote
Sharkbite fittings on PB pipe rjniles Plumbing 17 08-16-2011 01:33 PM
Tell me all about pex fittings! Red Squirrel Plumbing 10 01-23-2010 05:48 PM
Propane lines in an RV...Flare Fittings K-mann Plumbing 3 09-18-2008 09:06 AM
SharkBite fittings... cgerikh Plumbing 12 05-21-2008 01:04 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
