#31 | |
call me E
Sharkbite FittingsQuote:
![]() when to use teflon tape?
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | jbfan (12-07-2012) |
#32 | |
#33 |
Sharkbite Fittings
The question of longevity is a simple one for me:
1) A SB fitting relies on a rubber o-ring to make the seal. That o-ring will fail at some point - probably not "catastrophically", but it'll begin with a little weeping, then develop into a pin hole leak which is exactly what you were trying to fix the first time around. 2) The fewer parts required to make a fitting, the less opportunity there is for it to fail. (Lots of little bits and pieces in a SB). A brass PEX coupling is just one solid piece - nothing to go wrong unless there's some factory defect in it. 3) Quality of the materials. When working with PEX, I prefer brass fittings to EP (engineered plastic) fittings. Expansion connections are also better than any of the others (crimp rings, clamps, SB, compression, press). That's why I relegate SB to the handyman category. They'll save you some time and get you out of a jam with little to no money invested in tools or training. They're a decent product, but not at all comparable to a proper PEX expansion ("ProPEX") connection. Last edited by Ishmael; 12-08-2012 at 07:39 AM. |
| The Following User Says Thank You to Ishmael For This Useful Post: | digitalplumber (12-08-2012) |
#34 | |
This is the kind of informative answer I was looking for, whether pro or con. Guess I should have done a poll instead. Thanks
digitalplumber is just a name for use here, I am not a plumber! |
| Display Modes | |
| SharkBite Fittings OK? | abracaboom | Plumbing | 18 | 10-22-2012 03:59 PM |
| sharkbite fittings?? | Just Bill | Plumbing | 14 | 01-01-2011 08:50 PM |
| hePEX & Sharkbite Fittings | Docfletcher | Plumbing | 3 | 11-16-2010 04:50 PM |
| Sharkbite brand PEX fittings at Home Depot | rjniles | Plumbing | 1 | 03-16-2010 08:33 PM |
| SharkBite fittings... | cgerikh | Plumbing | 12 | 05-21-2008 02:04 PM |
