Sharkbite Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2012, 10:16 PM   #1
Rewards Points: 70
Sharkbite Fittings
I need some professional opinions here.
I am the Pres of an Condo HOA. Our management company use a plumber that makes all of his repairs with sharkbite fittings.
The last one which was easily accessable in the attic, he charged us 250.00.
My question is: Do you guys and gals feel that sharkbite fittings are an acceptable long term way to fix PEX? or should he be splicing and using rings?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 12-06-2012, 10:52 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
Why use SB's on pex?
Old 12-06-2012, 11:06 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
$250.00! Could have done it yourself and saved $240.00!
As for long term,SB will stand the test of time.
they are also safe to used behind walls.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
digitalplumber (12-07-2012)
Old 12-07-2012, 03:11 AM   #4
Rewards Points: 166
Sharkbites are actually more reliable than most people presume. However, PEX isn't all that difficult to work on anyway and for 250 you should be able to ask him to use crimp ring fittings if that's what you want. He should have the tools to do it and if he doesn't then maybe consider another plumber.
dftc is offline   Reply With Quote
The Following User Says Thank You to dftc For This Useful Post:
Old 12-07-2012, 06:01 AM   #5
Rewards Points: 1,294
I doubt you get any sympathy on cost here and that's one reason of many why people DIY. But what failed that caused a repair to be made?
Old 12-07-2012, 06:37 AM   #6
Rewards Points: 70
Old 12-07-2012, 06:38 AM   #7
Rewards Points: 70
Yes unfortunately, this complex is 100 miles away and not my unit. I just wanted to get a feel for the SB repair, for long term especially since he is charging so much.
Old 12-07-2012, 06:39 AM   #8
Rewards Points: 70
Thanks, just wanted to get a consensus for long term permanent repair.
Old 12-07-2012, 06:42 AM   #9
Rewards Points: 70
Not looking for sympathy, I know the price is outrageous. Its not my unit, but the management company sends this guy when they get a call from tenants, even when its not the HOA's resposibility.
From the limited information on the bill, apparently the pex developed a pinhole leak. Just looking for a concensus on whether the SB is a valid long term repair and or what you guys do.
Old 12-07-2012, 11:26 AM   #10
Civil Engineer
Rewards Points: 4,790
I don't get why you and others on this forum think $250 is outrageous. There is zero information on how far the plumber had to travel, how long it took him to perform the work, whether he has a standard minimum charge etc. As to the comment that you could do the work yourself for $10, that refers only to the estimated cost for the fitting and perhaps new PEX, it does not take into account travel time to and from the site, time on site, cost of tools and equipment etc. Seems to me that a lot of DIY folks value their time at zero, hence conclude that tradespeople are charging outrageous amounts of money because they do not (and should not) value their time at zero.
The Following 3 Users Say Thank You to Daniel Holzman For This Useful Post:
Ishmael (12-07-2012), Ocelaris (12-28-2012), TheEplumber (12-07-2012)
Old 12-07-2012, 11:39 AM   #11
As long as an approved fitting was used and installed properly, I don't see the issue. As for the price, $250 sounds come rely reasonable: 2 hour minimum @ $100/hr plus a $50 truck charge. Sounds like he didn't even charge for materials. If you want cheap, hire a handyman. BUT, don't expect it to necessarily be done right.
hvac benny is offline   Reply With Quote
Old 12-07-2012, 12:29 PM   #12
I agree 95%. This was likely an emergency call(?) which may mean he had to pick up and leave one job to respond - possibly with a helper/apprentice along for the ride. The only argument I have with your statement, hvac benny, is that I'd expect a handyman to use sharkbite fittings - not a professional.
Ishmael is offline   Reply With Quote
Old 12-07-2012, 07:09 PM   #13
Yes, sharkbites are acceptable. He did you right. I have used them, and will continue to use them. I do not like them, but hey, everyone does it. People ask me all the time if they paid to much. I give everyone the same response, " I do not know what type of arrangement you had" As to why he used a shark bite, we do not know the circumstances surrounding the call. It could have been 3 in the morning on a steep frozen platform 60 feet in the air. The plumber might of had to climb and wanted as few tools as possible. Maybe the crimpers would not fit in a really tight space. Your making a lot of trouble for yourselves and others saying a price was to much.
paintdrying is offline   Reply With Quote
Old 12-07-2012, 07:25 PM   #14
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
OP indicated that there was a pin hole in the pex causing the leak and the pex was easily accessible from the attic. $10 for the fitting and 20 minutes tops to cut the pex and attach fitting. A pex pipe cutting toll is all that was needed by the "pro"$250 is ALOT for most people,hence this DIY web site.
As for DIY folks valuing their time as zero,one can look it as paying themselves $240.00 for a 1/2 hr of work!
Old 12-07-2012, 08:03 PM   #15
Plumber
Rewards Points: 682
You do not have enough info to say the price was too high except the OP's vague description. I'm not saying it was a justified charge, however, consider travel time, hunting down or waiting for authorization, overtime/after hrs, finding a hidden shut off valve or curb stop, perhaps waiting on water dept. The list goes on..... and then we get into costs of running the shop- overhead costs the customer doesn't consider
These are things that happen on multiple calls- someone needs to pay for them. If its the plumber then he'll be out of bussiness
SharkBite Fittings OK? abracaboom Plumbing 18 10-22-2012 02:59 PM
sharkbite fittings?? Just Bill Plumbing 14 01-01-2011 07:50 PM
hePEX & Sharkbite Fittings Docfletcher Plumbing 3 11-16-2010 03:50 PM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
SharkBite fittings... cgerikh Plumbing 12 05-21-2008 01:04 PM
