Sharkbite Fittings
I need some professional opinions here.
I am the Pres of an Condo HOA. Our management company use a plumber that makes all of his repairs with sharkbite fittings. The last one which was easily accessable in the attic, he charged us 250.00. My question is: Do you guys and gals feel that sharkbite fittings are an acceptable long term way to fix PEX? or should he be splicing and using rings? Thanks |
Why use SB's on pex?
As for long term,SB will stand the test of time. they are also safe to used behind walls. |
Sharkbites are actually more reliable than most people presume. However, PEX isn't all that difficult to work on anyway and for 250 you should be able to ask him to use crimp ring fittings if that's what you want. He should have the tools to do it and if he doesn't then maybe consider another plumber.
I doubt you get any sympathy on cost here and that's one reason of many why people DIY. But what failed that caused a repair to be made?
Thanks |
Not looking for sympathy, I know the price is outrageous. Its not my unit, but the management company sends this guy when they get a call from tenants, even when its not the HOA's resposibility. From the limited information on the bill, apparently the pex developed a pinhole leak. Just looking for a concensus on whether the SB is a valid long term repair and or what you guys do. Thanks |
I don't get why you and others on this forum think $250 is outrageous. There is zero information on how far the plumber had to travel, how long it took him to perform the work, whether he has a standard minimum charge etc. As to the comment that you could do the work yourself for $10, that refers only to the estimated cost for the fitting and perhaps new PEX, it does not take into account travel time to and from the site, time on site, cost of tools and equipment etc. Seems to me that a lot of DIY folks value their time at zero, hence conclude that tradespeople are charging outrageous amounts of money because they do not (and should not) value their time at zero.
As long as an approved fitting was used and installed properly, I don't see the issue. As for the price, $250 sounds come rely reasonable: 2 hour minimum @ $100/hr plus a $50 truck charge. Sounds like he didn't even charge for materials. If you want cheap, hire a handyman. BUT, don't expect it to necessarily be done right.
Yes, sharkbites are acceptable. He did you right. I have used them, and will continue to use them. I do not like them, but hey, everyone does it. People ask me all the time if they paid to much. I give everyone the same response, " I do not know what type of arrangement you had" As to why he used a shark bite, we do not know the circumstances surrounding the call. It could have been 3 in the morning on a steep frozen platform 60 feet in the air. The plumber might of had to climb and wanted as few tools as possible. Maybe the crimpers would not fit in a really tight space. Your making a lot of trouble for yourselves and others saying a price was to much.
As for DIY folks valuing their time as zero,one can look it as paying themselves $240.00 for a 1/2 hr of work! |
These are things that happen on multiple calls- someone needs to pay for them. If its the plumber then he'll be out of bussiness |
| All times are GMT -4. The time now is 12:34 AM. |
