Old 11-05-2012, 05:05 PM   #1
Sharkbite fitting at slight angle
I just installed a new shower valve in my master bathroom. I must have cut the pipe just a little to long because the pipe is at a very slight angle. It did click in and there are no leaks right now. I'm curious if this is okay or do I need to redo this pipe to avoid issues in the future. Like I said nothing is leaking I'm just a little paranoid. Here are some pictures.
Thanks for looking!
joebanks is offline   Reply With Quote
Old 11-05-2012, 05:09 PM   #2
I would fix it, why take a chance behind a wall like that?
Old 11-05-2012, 06:10 PM   #3
Ugh yeah I know. Next time I'm just going to solder in place instead of marking and soldering outside the wall.
Old 11-05-2012, 11:22 PM   #4
Or use Pex.
Old 11-05-2012, 11:35 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Just move the board above the valve assembly, and it should flex back to straight.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
which way to cut baseboards for inner angle fitting? KUIPORNG Carpentry 22 05-30-2007 03:26 PM
