Shark Bite: Totally Confused - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By RRH
Old 12-10-2016, 04:51 PM   #1
Rewards Points: 16
Shark Bite: Totally confused
I'll try to make this simple. Kitchen cabinets being replaced in a couple of weeks. I had a slight leak at one of the shut off valves for sink. They are 1/2 and then 3/8 at the compression fitting end. The lines come into the house about 5 feet from sink and the former homeowner used lengths of braided steel line to supply faucet. I just replaced the old shut off valves with quarter turn shark Bite angle stops. these are 1/2 inch with 3/8 compression fittings.
Similar dimensions to the older valves I replaced. I attached the braided lines to the Shark bite fittings with no problem.
Here is where my confusion arises. I do not like the long run of braided hoses.
I want to run PEX or CPVC from the shut off valves along the base of cabinets and use T setup for new icemaker and dishwasher. I see shark bite has the proper size T (1/4 in for icemaker and 3/8 for dishwasher.
I cannot seem to attach PEX to the angle stop??
It is a 1/2 supply into home and a 3/8 compression at other end. PEX does not fit nor does CPVC. What am i missing here?
I could keep the long braided lines and put in a Shark Bite male connector on the end of the braided lines
This seems like a mess of connections.
How do i simply attach PEX to the 3/8 end of the shut off valve or are these designed for the braided hose only?? I would think since it is a compression fitting it would be simple but i am not understanding this.
Lastly, why does supply to sink seem to be 1/2 to 3/8 and back to 1/2. Why didn't the former homeowner just keep all 1/2. I am new to plumbing and really need help on this.
The Shark Bites are way easier than sweating a connection but compatibility seems to be an issue even though Shark Bite says it will work with PEX and CPVC.
spivey44 is offline   Reply With Quote
Old 12-10-2016, 05:05 PM   #2
Rewards Points: 13,712
Re: Shark Bite: Totally confused
Got some pictures so we can see what your seeing?
"there 1/2", 1/2" what coming out of the wall?
Old 12-10-2016, 05:13 PM   #3
Rewards Points: 16
1/2 inch copper. the shark Bites fit right on the copper supply lines. The other end of the Shark Bites are 3/8 compression fittings. Here is a link
http://www.sharkbite.com/product/angle-stops/
I want to fit the PEX or CPVC to the compression fitting .
Maybe I should switch out the shut off from a 1/2 x 3/8 to 1/2 x 1/2 ?
Old 12-10-2016, 05:48 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 676
You will need to abandon the angle stops- at least at the location they are now.
Replace them with a tee to feed the branch line to the ice maker and DW. Then add the stops to control each fixture.
Yot could also try a quick tee if it's what you need- https://www.plumbingsupply.com/quick-tee-adapter.html
Old 12-10-2016, 06:15 PM   #5
RRH
Rewards Points: 298
Yes,
So remove the current angle stops and replace with 1/2 sharkbite fitting to go from the 1/2 copper to 1/2" pex.
Run pex 5 ft to the sink. Then do what you want. One valve.
Or then tees and have a separate shutoff for each fixture.
Yodaman likes this.
RRH is online now   Reply With Quote
Old 12-10-2016, 07:23 PM   #6
Rewards Points: 16
Originally Posted by RRH View Post
Yes,
Appreciate the help. i guess 3/8 pex not good. Any idea why so many people go from 1/2 inch down to 3/8 and then back to 1/2 at the sink?
Thanks again
Old 01-10-2017, 09:15 PM   #7
RRH
Rewards Points: 298
Thanks again
I have not seen that.
It is always 1/2" to a shutoff valve. Then short run of 3/8 to the faucet.
Sometimes a long run of 3/8 to a refrig. Where you don't need the volume.
confused and need help mammaw810 HVAC 12 04-10-2012 11:26 AM
What are the risks of using LED bulbs in a totally enclosed fixture? sc2k2 Electrical 9 12-06-2011 10:31 PM
Leveling a ceiling in an unfinished basement - I'm TOTALLY lost and confused... mensrea Carpentry 10 03-22-2011 06:14 AM
Replacing switch -- TOTALLY CONFUSED! JGLA Electrical 1 11-14-2010 02:33 PM
First new roof ... totally confused adawg Roofing/Siding 52 10-10-2007 09:02 PM
