Shark Bite Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2011, 05:09 PM   #31
Pex and copper have the same O.D. you can use the same sharkbite fitting on both types of piping.
Yes, that's true. One thing to remember however is that you should use the stiffeners that come in the sharkbite fitting package ONLY with pex. I've heard, but never witnessed, that it can cause leaks when used with copper.
VIPlumber is offline   Reply With Quote
Old 03-21-2011, 10:06 AM   #32
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by Red Squirrel View Post
Did not know that at the time, but yeah it looks like they are compatible. Figured the ends were made different. Somehow, I would not really trust them on copper though... but seems to be what my contractor used for the kitchen, so guess it is accepted. I did not figure the teeth would be able to actually dig in solid enough into copper.
The new PRO-PRESS fitting system for copper utilizes a similar function for it's fittings.
Journeyman Plumber
Old 03-21-2011, 11:58 AM   #33
Rewards Points: 1,010
I haven't used shark-bite fittings with Pex, but I have used them with copper. Two years going and no problems at all.
spaceman spif is offline   Reply With Quote
shark bite fitting Boston Bean Plumbing 6 09-12-2010 01:01 PM
Splicing Shark Bite Jack E Plumbing 11 05-04-2010 06:48 PM
Shark Bite fittings carlymoto Plumbing 5 11-27-2009 11:31 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 03:01 PM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 11:29 AM
