#1 |
shark bite connectors
I have an existing water heater that will son be replaced. The existing water heater has copper lines running off of it.
I was thinking of using shark bite connectors along with the flex tubing to connect to the existing copper supply lines. http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051 has anyone used this procedure rather than the standard soldering method? I'd love to AVOID soldering all together but figured I'd get the opinions first. |
#2 | |
MarginallyQualified
shark bite connectorsQuote:
this would be a great opportunity to remedy that shortcoming. Get some help and learn a new skill. |
#3 |
Those fittings work great.Used many of them over the years.
#4 | |
call me E
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#5 |
Persona Non Grata
shark bite connectors |
#6 |
tarheel - I have actually soldered ONCE this past spring. Had to replace a busted copper line in the garage from a piece of ice bustingout the side a number of years ago. I broke down and attempted to solder. Oh, it worked with no problems but it looked like crapola!!!!!
I work at Home Depot and I am starting to cross train within a few departments. Plumbing being one of them. Today was my first day of plumbing training and I was introduced to the shark bite/PEX route compared to the soldering route.................I was happier than a pig in mud!!! |
#7 | ||
MarginallyQualified
The next attempt should be better. Keep trying. Quote:
They should NOT be used for planned work. Plan your work. Do it right. |
#8 |
nope, no leaks but visually it looks like it was done by a drunk plumber
#9 |
I used shark bite to connect the copper pipe to pex pipe while doing remodeling. It's been 1.5 years so far and no problem at all.
A picture is worth a thousand words. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#10 |
OK, so far, for the most part, I'm hearing nothing but positive about these pex/SB connectors.
If these PEX/SB connectors work VERY WELL, why can they not be used instead of copper piping for the water heater? What am I misunderstanding? |
#11 | |
MarginallyQualified
I have two in my own basement right now. What is being said is twofold: a) learn the proper skill b) use that skill at the proper time |
#12 |
call me E
The UPC does not allow pex to be connected to a water heater. Has to be 18 or 24" away-can't remember which
#13 |
ahhh, the code.
I will post some pictures as well as dimensions and i will get a confirmed "don't do it" or "go ahead"
#14 | |
Doing it myself
wait... ![]() ![]() ![]()
Journeyman Plumber |
| Display Modes | |
| Gator bite & shark bite | jamjr74 | Plumbing | 7 | 04-22-2012 08:55 AM |
| Shark Bite fittings | Red Squirrel | Plumbing | 32 | 03-21-2011 11:58 AM |
| shark bite fitting | Boston Bean | Plumbing | 6 | 09-12-2010 01:01 PM |
| Splicing Shark Bite | Jack E | Plumbing | 11 | 05-04-2010 06:48 PM |
| Replace PEX fitting with Shark Bite Push Connector? | larrybr45 | Plumbing | 3 | 01-27-2008 03:01 PM |
