-   -   shark bite connectors (http://www.diychatroom.com/f7/shark-bite-connectors-150358/)
crankbait09 07-15-2012 05:08 PM
29 Attachment(s)
I have an existing water heater that will son be replaced. The existing water heater has copper lines running off of it.
I was thinking of using shark bite connectors along with the flex tubing to connect to the existing copper supply lines.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
has anyone used this procedure rather than the standard soldering method?
I'd love to AVOID soldering all together but figured I'd get the opinions first.
TarheelTerp 07-15-2012 05:31 PM
If you don't already know how to solder pipe & fittings...
this would be a great opportunity to remedy that shortcoming.
Get some help and learn a new skill.
ndmick 07-15-2012 07:13 PM
Those fittings work great.Used many of them over the years.
TheEplumber 07-15-2012 07:28 PM
199 Attachment(s)
The dark side of me hopes sharkbites start to fail soon like PB piping did. Then plumbers will have job security for a while longer :jester:
VIPlumber 07-15-2012 07:49 PM
Welcome to the dark side.:whistling2:
crankbait09 07-15-2012 07:50 PM
29 Attachment(s)
tarheel - I have actually soldered ONCE this past spring. Had to replace a busted copper line in the garage from a piece of ice bustingout the side a number of years ago. I broke down and attempted to solder. Oh, it worked with no problems but it looked like crapola!!!!!
I work at Home Depot and I am starting to cross train within a few departments. Plumbing being one of them.
Today was my first day of plumbing training and I was introduced to the shark bite/PEX route compared to the soldering route.................I was happier than a pig in mud!!!
TarheelTerp 07-15-2012 07:55 PM
Did it leak?
The next attempt should be better. Keep trying.
I work at Home Depot...
Sharkbites have a place. An example of that place is at 2AM with water filling the basement and a corroded over valve that won't close.
They should NOT be used for planned work.
Plan your work. Do it right.
crankbait09 07-15-2012 08:12 PM
29 Attachment(s)
nope, no leaks but visually it looks like it was done by a drunk plumber
Stephen S. 07-16-2012 01:47 AM
I used shark bite to connect the copper pipe to pex pipe while doing remodeling. It's been 1.5 years so far and no problem at all.
crankbait09 07-16-2012 08:24 AM
29 Attachment(s)
OK, so far, for the most part, I'm hearing nothing but positive about these pex/SB connectors.
If these PEX/SB connectors work VERY WELL, why can they not be used instead of copper piping for the water heater? What am I misunderstanding?
TarheelTerp 07-16-2012 09:51 AM
No one is saying that they won't work.
I have two in my own basement right now.
What is being said is twofold:
a) learn the proper skill
b) use that skill at the proper time
TheEplumber 07-16-2012 09:55 AM
199 Attachment(s)
The UPC does not allow pex to be connected to a water heater. Has to be 18 or 24" away-can't remember which
crankbait09 07-16-2012 09:59 AM
29 Attachment(s)
ahhh, the code.
I will post some pictures as well as dimensions and i will get a confirmed "don't do it" or "go ahead" :)
Alan 07-16-2012 10:21 AM
If I was a sober plumber, i'd take offense at that...
wait... :huh::huh::confused1::mellow:
Originally Posted by theeplumber (Post 966982)
the upc does not allow pex to be connected to a water heater. Has to be 18 or 24" away-can't remember which
18" .
