Shark-bite Connector Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2009, 08:05 AM   #1
Shark-bite connector problem
I have a 3/8" - 1/2" Shark-bite connector and I need to remove the white
plastic insert in the connector before I insert my 3/8" copper pipe. Does anyone know how to remove the plastic insert without damaging the connector?
jgs1951 is offline   Reply With Quote
Old 07-21-2009, 08:52 AM   #2
The instructions for removing the insert are on the package. You should only have to push down on the beige plastic ring and work the insert out by tilting it side to side.
jerryh3 is offline   Reply With Quote
Old 07-21-2009, 09:00 AM   #3
Registered User
Termite's Avatar
The same instructions are on the SharkBite website and can be downloaded last time I checked.
Old 07-21-2009, 10:58 AM   #4
Thanks Guys, your replies were very helpful
insect pests in the home that bite tomsjule Pest Control 24 06-15-2009 11:45 AM
Plastic/Shark Bite Fittings AJ&J Plumbing 8 03-25-2009 09:09 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 03:01 PM
Anyone use Shark Bite? Good ? Bad? twilightcall Plumbing 9 01-14-2008 09:05 PM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 11:29 AM
