Shark Bite! - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2010, 01:34 PM   #1
Shark bite!
How do I install a shark bite on a half inch copper line?
I want to hook a stainless mesh washing machine line to a hot water line.
Tell me exactly.....I am under the house with this and have very little working room.
Thanks!
Chuckwagon is offline   Reply With Quote
Old 01-07-2010, 02:00 PM   #2
Rewards Points: 150
is this 5/8"od copper?if so,cut out the section needed to install the tee.
rudolph58 is offline   Reply With Quote
Old 01-07-2010, 03:33 PM   #3
Huh?? I just want to install a shark bite on the half inch copper line that has the male connector for a hot water sink line connection. This connection will be under the house about 6 inches above the ground.
I might have to couple two 30 inch sink lines together to make it reach the sink cabinet.
Should I use the metal shark bite or the pvc shark bite? The sink line connectors are metal.
Old 01-07-2010, 06:38 PM   #4
Remodeling Contractor
use a brass sharkbite.
Old 01-07-2010, 06:49 PM   #5
I thought i saw a post where you needed to remove the plastic insert for copper but not for pex.they also make a release tool if you need to undo your first fit
Old 01-07-2010, 06:57 PM   #6
Is this just a straight pipe? If so, there are sharkbite to threaded fittings. Do you have a shutoff somewhere?
jerryh3 is offline   Reply With Quote
Old 01-07-2010, 07:09 PM   #7
It is a plain half inch copper water line. I am going to shut off the water at the main......install the shark bite........screw on a flexible mesh water line......run it through a bored hole through the floor into the sink cabinet......hook up the water line to to the faucet and.......VOILA!!
(hopefully)
If anything in my scenario sounds amiss, please tell me.
Thanks!
Old 01-07-2010, 08:19 PM   #8
If you are planning on cutting into a 1/2" copper pipe in you crawlspace then use a sharkbite to connect a stainless steel supply line to it then run that supply line to through the floor to a sink up there then DON'T do it. that is awful.. you need to run a pipe not a supply line from the crawlspace to the sink then install a shutoff valve then a supply line. be sure to properly fasten the pipe too. You will be glad you did it correctly when you don't have a flooded crawlspace.
plumber Jim is offline   Reply With Quote
Old 01-07-2010, 08:56 PM   #9
Rewards Points: 150
plain old copper comes in many different sizes,especially if it roll copper.if it's rigid than it's probably 5/8"or 7/8" OD(outside diameter) tubing that in plumbing we call 1/2"or 3/4" water pipe.try using 5/8"OD roll copper instead of that conglomeration your trying to use up into the cabinet and put a 5/8"ODx3/8"OD straight compression stop on that end of pipe to hook onto your supply tube.
Old 01-07-2010, 09:23 PM   #10
How do I hook up to the half inch copper pipe under the house?
Do I use a shark bite to hook up that 5/8 od roll copper tubing to the place that I will cut the half inch pipe under the house?
Speaking of that compression stop......is that a something that does not have to be soldered?
Thanks for answering these questions.
Chuckwagon
Old 01-07-2010, 10:23 PM   #11
Rewards Points: 150
yes to the first ? and no to the second(a couple of crescent wrenches)
Are shark bites reliable? speedster1 Plumbing 12 12-21-2009 10:27 PM
Shark Bite fittings carlymoto Plumbing 5 11-27-2009 11:31 PM
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 03:01 PM
Anyone use Shark Bite? Good ? Bad? twilightcall Plumbing 9 01-14-2008 09:05 PM
plumbers shark bite fittings jburkeg Plumbing 9 11-12-2007 11:29 AM
