#1 |
Shared use of a shower mixer?
With the walls open to the studs, I can see the back side of the shower mixer. (Old and new bathrooms share this interior wall) It's a seldom used shower and not really needed. The valves are inside the new(under construction) shower stall where I really could use a (second) source of water for a hand-held fixture near the bench.
Is it possible to tap into the existing mixer/valve or copper H20 pipes and use that source to install another fixture on the oppolsite side of the wall? |
#2 |
Journeyman Plumber
If your asking to install a new vavle on other wall, sure you can, as long as you tap into 3/4" cold an hot feed from somewhere, and run 1/2" lines to the valve from there.
#3 |
Do I understand correctly?
Does that mean that is IS O.K. to tap into one set of water pipes to feed two different shower heads? (Only one would be in use at a time, of course.) Thanks again Ron, for your help, Katie |
#4 | |
Shared use of a shower mixer?Quote:
Or will this be for another fixture? If so, what type of fixture? Are these 1/2" copper pipe or larger? You can use these for supply for a your new shower from the old shower if you connect before the old mixer and not after. If both showers are used at the same time then you may see a reduction in pressure. |
#5 |
Journeyman Plumber
What redline said,
You must tie in before the existing valve, and not after it. |
#6 |
Yes, the pipes bringing the hot and cold water are 1/2". I haven't chosen the fixture yet, but I know a trustworthy plumbing supply retailer who will help me decide, now that I know what to aks for. Thanks so much, guys. -Katie
| Display Modes | |
| Another newbie building a tile shower | ChadC | Building & Construction | 7 | 08-25-2008 03:58 PM |
| All shower fixtures loose, what to do? | darsunt | Plumbing | 4 | 06-06-2007 01:01 PM |
| Bathroom Shower Help - PLEASE :) | OTEJUNK | Remodeling | 5 | 05-09-2007 11:33 AM |
| Installing a New shower facuet... | BDPNA | Plumbing | 8 | 01-18-2007 09:23 AM |
| Maxx Shower Walls Install on Metal Studs? | atilla137 | Plumbing | 2 | 11-21-2006 07:17 PM |
