-   -   Shared use of a shower mixer? (http://www.diychatroom.com/f7/shared-use-shower-mixer-3026/)
Katydid 07-10-2006 05:11 PM
With the walls open to the studs, I can see the back side of the shower mixer. (Old and new bathrooms share this interior wall) It's a seldom used shower and not really needed. The valves are inside the new(under construction) shower stall where I really could use a (second) source of water for a hand-held fixture near the bench.
Is it possible to tap into the existing mixer/valve or copper H20 pipes
and use that source to install another fixture on the oppolsite side of the wall?
Ron The Plumber 07-10-2006 07:54 PM
If your asking to install a new vavle on other wall, sure you can, as long as you tap into 3/4" cold an hot feed from somewhere, and run 1/2" lines to the valve from there.
Katydid 07-11-2006 01:59 PM
Thanks, Ron...
Do I understand correctly?
Does that mean that is IS O.K. to tap into one set of water pipes to feed two different shower heads? (Only one would be in use at a time, of course.)
Thanks again Ron, for your help,
Katie
redline 07-11-2006 02:34 PM
Will this be the hot and cold supply for the new shower stall?
Or will this be for another fixture? If so, what type of fixture?
Are these 1/2" copper pipe or larger?
You can use these for supply for a your new shower from the old shower if you connect before the old mixer and not after.
If both showers are used at the same time then you may see a reduction in pressure.
Ron The Plumber 07-11-2006 05:54 PM
What redline said,
You must tie in before the existing valve, and not after it.
Katydid 07-12-2006 03:47 PM
O.K. I understand.
Yes, the pipes bringing the hot and cold water are 1/2". I haven't chosen the fixture yet, but I know a trustworthy plumbing supply retailer who will help me decide, now that I know what to aks for. Thanks so much, guys. -Katie
