Shallow Well? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2011, 10:22 AM   #1
shallow well?
Can anyone Help????????????Hello. I have a shallow well. It will not hold pressure and pump would not cut off.. I have replaced with new tank and new check value. Took 4ever but it started holding pressure and had great water flow, for a day. Pressure is back to 15 and pump will not cut off. No leaks. I think to pump is just old. Please help. Justasking, Thanks
justasking is offline   Reply With Quote
Old 06-30-2011, 10:21 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How have you determined there are no leaks?
You have a jet pump next to your shallow well, or do you have a submersible in it? How far is it from the pump to the tank and pressure switch ? What is the elevation difference from the pump to your pressure tank and pressure switch? How many HP is the pump?
Journeyman Plumber
Cabinet too shallow for wall oven? knute General DIY Discussions 11 10-04-2015 01:43 PM
Help - Adding a third outlet off of 1 outlet, shallow box so no pigtailing stlramscards Electrical 20 02-01-2011 07:52 PM
need shallow kitchen sink ?? SteveDonohoe Plumbing 2 11-23-2010 06:12 PM
shallow hip roof ventilation pauln Roofing/Siding 2 08-10-2008 11:31 AM
Shallow Well Pump BillyD Plumbing 3 06-19-2008 08:25 AM
