Shaking Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-24-2010, 05:48 PM   #1
Shaking pipes
After five years living in my house the kitchen hot water pipe now vibrates when turned on. I need to turn the water on very high to avoid any vibration. The bathroom hot water does not. House was built in 1940. Previous owner had new copper plumbing put in ten years ago , or so. Except the last 2-3 feet of kitchen hot and cold water pipes, which are original galvanized pipes. Kitchen faucet is very old also. Might even be original.
Any help appreciated.
wurz is offline   Reply With Quote
Old 12-24-2010, 06:22 PM   #2
Check your bibb washers. They could be loose and vibrating when the faucet is turned on.
Work4living is offline   Reply With Quote
The Following User Says Thank You to Work4living For This Useful Post:
braindead (12-25-2010)
Old 12-25-2010, 05:45 PM   #3
Rewards Points: 558
It could be one or a combination of things like excessive amounts of air in the pipe, loose washer in faucet, small debris or gravel in the piping system; plumber never secured the water line properly.
epson is offline   Reply With Quote
Tags
air , shaking , vibrating pipes
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
