Sewer Vents - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2008, 08:36 PM   #1
Sewer Vents
I Have Small Bath Room With Sewer Vent And Drain Out Side Of Wall Next To Bath Room. It Is 5 Inch Dia I Want To Know If I Run A 5 Inch Pipe Thru Wall Under Floor Do I Still Need A Vent
For Sink Toilet And Corner Shower
The Main Vent Will Be Not Be More Than 8 Feet
Away From Them
WGC454 is offline   Reply With Quote
Old 11-25-2008, 09:04 AM   #2
Each fixture needs it's own vent connection that goes to the main vent line. Click on the link below for a typical drainage system set-up. Notice that each fixture has a line going to the main drain, and also a line going back to the main vent.
http://www.hometips.com/hyhw/plumbing/74drain.html
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Removing some vents rdmccaw HVAC 4 10-22-2008 01:00 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
