Sewer Smells From Shower Drains And Washer Drain. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2013, 10:31 AM   #1
Sewer smells from shower drains and washer drain.
Sewer gases coming up from showers on one side of house and through the washer vent on the other. house is 3 years old, two story, two vent pipes on roof on respective sides. I've seen sureseal ads, have poured water into accessible traps. Would positive ventilation be a solution?
Sewer sufferer is offline   Reply With Quote
Old 02-03-2013, 12:04 PM   #2
MarginallyQualified
Rewards Points: 2,464
Whatever may be going on with the vents...
the traps at each fixture should be stoppering those odors.
Have you had anyone in to check the DWV design/layout
and the quality of the work that was done?
Old 02-03-2013, 12:19 PM   #3
Roofmaster
Rewards Points: 2,172
Missing Traps, or Traps being siphoned. Vents improperly located.
Old 02-03-2013, 12:36 PM   #4
There mite be a clogged vent. The trap is getting siphoned out when the drain sucking for air. if it start to smell then but some water down the drain to stop the smell instill you get a chance to run a snake down the vent.
best handyman is offline   Reply With Quote
Washer Drain Overflows ryanb4614 Plumbing 2 03-20-2012 11:12 PM
Washer Backing up into basement shower Durt Ferguson Plumbing 21 08-26-2010 09:41 AM
Washer Drains..... Soap comes out of floor Drain?? choda_boy_04 Plumbing 2 01-21-2010 07:20 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
