Sewer Smells From My Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2011, 12:43 AM   #1
sewer smells from my toilets
Why does my bathrooms smell like sewer? this is a brand new home I need help please my 1 year inspection is up in July thanks 4 all your help.
tomball is offline   Reply With Quote
Old 06-01-2011, 12:45 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is there a tub or shower or sink you don't use?
XXX
Old 06-01-2011, 01:21 AM   #3
smell from toilet
no we use every bathroom in the home
Old 06-01-2011, 07:24 AM   #4
Lightfoot's Avatar
Rewards Points: 272
Are the toilets tight to the floor, or can you move them in a twisting motion? It's possible the toilets have loosened after the first year, causing the wax rings to break their seal, allowing vapors to escape. Sometimes you can tighten them down (carefully) again but i usually replace the wax ring, then tighten again in a few weeks and then check them again after a few months.
Lightfoot is offline   Reply With Quote
Old 06-02-2011, 02:34 PM   #5
Owner
LateralConcepts's Avatar
I would call the builder immediately if you haven't already. Make them aware of the problem before your warranty is up. Have them send someone to check it out. Sewer smells can be as simple as a p-trap that has just dried out; or a major problem, i.e. broken drain line, trap, vent stack, etc. inside a wall or under a slab.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 12:13 PM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 12:10 PM
funky sewer smells MeanGene Plumbing 9 08-17-2010 11:04 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
