Sewer Smell In My Trailer - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2011, 04:16 PM   #1
Sewer smell in my trailer
Need help with what could be causing a horrible crap smell in my trailer. All of a sudden it just started smelling really bad in the bathrooms and kitchen/washing area. So my father in law unplugged the air pump for the septic tank outside and the air cleared. I then paid 300.00 dollars to have the septic tank pumped. Right after the guy left I plugged the air pump back in and let it run for a few hours thinking the smell would clear and it didn't. So I unplugged it and left it unplugged for two months. Well my pipes when someone flushes are creaking so I decided to plug the air pump back in praying it wouldn't smell again and BAM! Still stinks. What should I do??? Any one had the same issues and knows whats causing this? The mobile home trailer I live in is about 20 years old and have lived in it for two years with no issues. Please help.
Nicole Hood is offline   Reply With Quote
Old 08-28-2011, 04:26 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome Nicole, to the best darn DIY'r site on the web.
Sounds to me like you have a failed check valve in your sewage line. I am not familiar with your setup so this is just an educated guess.
Mark
Old 08-28-2011, 04:28 PM   #3
Thank you Jack for replying back! Let's say this is the issue, if you were doing it yourself what would you do to fix it? Like your process of it?
Old 08-28-2011, 04:35 PM   #4
Experienced
Jackofall1's Avatar
Find the check valve under the trailer, cut it out and replace it with a new one, shouldn't take more that 30 minutes.
Mark
sewer gas smell when using washer cgratsch Plumbing 6 01-27-2014 12:09 AM
Back pitch sewer pipes and sewer smell..? HeatherJ Plumbing 15 04-23-2011 11:13 AM
Studor Mystery: Sewer Gas Smell StudorCrazy Plumbing 3 02-20-2010 11:49 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
