Sewer Smell In Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2010, 07:08 PM   #16
Rewards Points: 79
The 2" going vertically through the floor goes up through the roof. The 2" you see it tying into horizontally, the right end is coming from the kitchen sink.
AndyH24 is offline   Reply With Quote
Old 12-22-2010, 07:01 AM   #17
Stay-at-home GC
Yep, if that 1.5 vent is open into the floor it would sure smell. I don't think you can put an Air Admittance Valve (Studor) in an enclosed space. I believe the diaphragm flaps do wear out and you need to be able to replace them.
CplDevilDog is offline   Reply With Quote
Old 12-22-2010, 11:40 AM   #18
Homerepairguy's Avatar
Rewards Points: 998
+1
What he said about being able to replace the flaps sure sounds logical. Tying into an existing vent would be a "forever" solution.
HRG
Homerepairguy is offline   Reply With Quote
Old 12-22-2010, 11:15 PM   #19
Rewards Points: 79
Thank You to everyone for helping me with this problem. I ran a new vent line to the attic and tied it in. Everything seems to be working great! Here's a pic of how I ran it in the bathroom. I was too lazy to climb back up in the attic tonight to take a pic up there, I'll do that tomorrow.
Thanks again!
Old 12-23-2010, 12:15 PM   #20
Rewards Points: 150
Looks Good.
2 things I will say as a recommendation
1- Make sure to foam around the pipes where they go into the attic. This is as easy as pushing a button but depending on the ammount of insultion you use upstairs could save some energy
2- Going between floors I use fire block spray foam to fill the gaps. I heard it can slow a fire... $10.... I will believe the hype
Docwhitley is offline   Reply With Quote
Old 12-23-2010, 01:47 PM   #21
your work looks nice
as dock said, now is a good time to seal all penetrations you can find through to the attick space... plumbing, electrical, heating and cooling.
Ltnicks is offline   Reply With Quote
Old 12-23-2010, 10:06 PM   #22
Rewards Points: 150
Ltnicks... Are You a LT?
Also great time to look for spots where squirrels can get in...
Old 12-24-2010, 04:37 AM   #23
Rewards Points: 998
Andy,
Congrats for a job well done. Sleep easy from now on.
HRG
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Basement Shower Drain Gas Smell ThunderCAT Plumbing 10 07-30-2009 02:04 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
Sewer Smell in Bathroom dc11 Plumbing 3 11-07-2008 04:20 PM
