Old 09-13-2009, 09:24 PM   #1
Sewer smell in basement
Occasionally I'll get a sewer (rotten egg) smell waft through the entire house that originates in the basement. It's the strongest after using the shower and in the winter. Not sure if winter has anything to do with anything, I figured it was just because the house is closed up more. There is an open drain in the basement that someone hinted could be the problem because it was dry? Any ideas?
BangHeadHereX is offline   Reply With Quote
Old 09-13-2009, 09:39 PM   #2
GC/Master Plumber/Mech
Sounds like you are track with a dry drain. A simple cure is to use a cooking oil because it will not evaparate. Just fill the drain.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-15-2009, 02:22 AM   #3
check all your fixtures in your basement. You may have a floor drain, sink or tub/shower with a dried out trap. run water in them all and see if that helps. and the oil trick helps too.
plumber Jim is offline   Reply With Quote
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Sewer Smell in Bathroom dc11 Plumbing 3 11-07-2008 05:20 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Sewer gas smell in basement when doing laundry on main floor Bornintc Plumbing 1 01-17-2007 12:04 PM
