Sewer Odor In Shower But Trap Has Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2012, 10:02 AM   #16
a few pictures of the inside of the shower would help
Old 08-17-2012, 11:37 AM   #17
Attached are photos from the inside.
Sewer Odor in Shower But Trap Has Water-image-2973504950.jpg   Sewer Odor in Shower But Trap Has Water-image-700984803.jpg
the1hangingchad is offline   Reply With Quote
Old 08-17-2012, 11:52 AM   #18
Rewards Points: 150
My guess would be...
Trap is too deep and nothing can flush out of it, so all the crap just settles in the trap.
Run a snake down the vent on the roof to see if anything built a house in it lol
Hammer450R is offline   Reply With Quote
Old 08-17-2012, 12:37 PM   #19
You know, one thing I noticed is the water in the trap has a film on top of it - I assumed that was normal but since the trap is pretty deep, I wonder if that could be the cause.
Old 08-17-2012, 12:40 PM   #20
Rewards Points: 150
You gotta think a shower doesnt have the force of downflow like a tub or toilet, so its just slowly coming out the other side of the trap. I'd bet its nasty in there.
On second look, the trap exit is normal its just the down tube is long which would help the cause not hurt it.
Im going back to blocked vent!
Old 08-17-2012, 12:46 PM   #21
Rewards Points: 150
Just out of curiosity, how many vent tubes exit the roof and what size are they...and how many bathrooms do you have in the house?
Old 08-17-2012, 12:52 PM   #22
Two vent tubes - unsure of size but one looks larger than the other. Three full baths. But keep in mind that this problem only came about after the plumber moved the drain, so the overall setup of the house shouldn't be an issue.
Old 08-17-2012, 12:55 PM   #23
Rewards Points: 150
Do small animals have access to your roof? I would snake the vents to make sure.
Old 08-17-2012, 09:38 PM   #24
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Just for the record : scratch my idea
Journeyman Plumber
Old 08-17-2012, 10:02 PM   #25
Home Remodeler
Rewards Points: 164
Poor some bleach and see if that improves the smell.
mikey48 is offline   Reply With Quote
Old 08-18-2012, 09:20 AM   #26
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Not sure if it means anything, but it looks like the trap is made up using elbows instead of a pre-made trap. This may be why the trap is set so deep.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
ben's plumbing (08-18-2012)
Old 08-18-2012, 09:34 PM   #27
Rewards Points: 582
sorry to hear of your problem with the shower.....all good advice..I can tell you not a very good job....could have used premade trap it would have fit...I believe the trap seal is being pulled allowing sewer gas to enter the house...most likely cause venting... ben
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (08-19-2012), TheEplumber (08-18-2012)
Tags
odors , plumbing , trap
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 01:24 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
