Old 03-19-2009, 07:45 PM   #1
sewer odor coming back up through sink
Please Help! My kitchen stinks! LOL I just bought a house that has the Main sink and then another smaller sink in the island. The problem is that when water is drained from the main sink the septic odor comes up through the drain in the island sink with enough pressure to pop the plug out. After looking at it I have discovered that they used the air admittance valves under both sinks instead of having the vent up through the roof. I have replaced the valves with no improvement. If I take the valves off it seems to work fine with no odor, but the water overflows through open vent. Anyone have any ideas?
terryan55 is offline   Reply With Quote
Old 03-20-2009, 09:11 AM   #2
there should have put a island vent .is the a trap . I used provents before with no problems .but you need a trap that is what seals out the smell
metx is offline   Reply With Quote
Old 03-20-2009, 11:25 AM   #3
There is a trap under the sink, but the pressure blows right past the water in it and will even blow out the drain plug if it is in.
Old 03-20-2009, 11:36 AM   #4
HVAC / Plumbing
Is this something that just started or has it been like this since you moved in ??
kenmac is offline   Reply With Quote
Old 03-23-2009, 04:12 PM   #5
This has been going on since I moved in.
Old 03-23-2009, 10:35 PM   #6
Safe, Most of the Time!!
brokenknee's Avatar
Did you purchase a quality AAV or a cheap one?
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 03-24-2009, 12:54 AM   #7
I you already have a trap in each individual sink: the main , and the island,
then the problem is with the vent. Each sink should have its own vent
because probably the two sinks are far away from each other. The vent in the island is more difficult to install.
Gabriel24 is offline   Reply With Quote
Old 03-24-2009, 06:15 AM   #8
can you fill the sink a little and watch it drain? Does the water slowly drain and bubble?
that part about blowing out the drain plug is very unusual. Never heard of that before.
II Weeks is offline   Reply With Quote
Old 03-25-2009, 11:13 AM   #9
plumbing contractor
PLUMBINGITALL's Avatar
I know what your saying and have had it happen before. What is happening is when you drain the main sink it sends positve pressure to the aav and the aav only opens with negitive pressures. So what i would do is look at the drain and see were the main sink ties in and rerout it to tie in behind were the island sink hooks up. Are you will have to get a vent to open air from the island.
PLUMBINGITALL is offline   Reply With Quote
old cement utility sink helpmyhusband Plumbing 26 05-14-2013 11:02 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 06:28 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
