Sewer Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2009, 11:21 PM   #1
Question
sewer lines
my sewer line from the house to the septic tank is about 50 years old and is spliced, patched and broken is several places. i have decided to replace the line. i have average plumbing skills, and can run a backhoe. the problem lies that i have to "reroute" the line around a house trailor that has been put in since. i am looking for suggestions/how to trips to do this. the existing line is 4" and i am planning to replace it with the same size. i just am not sure about if i can put a sweeping 90 in or have to use all 45s. i would appricate any advice.
thanks
altop is offline   Reply With Quote
Old 10-28-2009, 06:46 AM   #2
Remodeling Contractor
Seeping 90's are fine, just maintain an even and adequate slope.
Old 10-28-2009, 09:16 AM   #3
Rewards Points: 1,448
Don't forget that the added length of pipe to go around the trailer results in a greater (vertical) drop requirement from house drain outlet to septic tank.
Old 10-28-2009, 06:47 PM   #4
i went out and measured it and it is just under 100'.. i figured with the sweeps it will be right at 100'. so i would need a 1' drop over the entire line... right?
Old 10-28-2009, 08:03 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
1/4" per ft or 3-4% slope
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-28-2009, 11:00 PM   #6
i know this might sound like a dumb question... but what kind of pipe do i need? i know i can use standard sch. 40 pvc... is that my only option?
cleaning sewer lines with pressure washer ponch37300 Plumbing 3 07-06-2009 09:26 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 05:19 PM
