Sewer Line Material Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2011, 10:16 PM   #1
Rewards Points: 18
Sewer line material help
I live in a house built in 1977-78 in michigan and was wondering what material my sewer pipe is?
In my basement where the line enters, it is large diameter pvc, but does that mean it is pvc all the way to the street or could it change somewhere in between?
Thanks or any help
detroit_fan is offline   Reply With Quote
Old 05-08-2011, 10:22 PM   #2
BIGRED
Rewards Points: 252
Yes it could. You could have clay tiles part way, then into a mission coupling, then into PVC or it could be cast iron into a mission coupling, then into the PVC.
Grampa Bud is offline   Reply With Quote
Old 05-08-2011, 10:27 PM   #3
Rewards Points: 18
Thanks for the fast reply. I was asking because I was wanting to plant a small tree in my front yard, but it would be near the sewer line. I thought if it was pvc it would have less of a chance of getting roots into the line, but not sure I want to risk it if it's another material.
Old 05-08-2011, 11:09 PM   #4
BIGRED
Rewards Points: 252
What kind of tree? Does the sewer line come through the basement floor of your home or somewhere up the wall on the street sideof the house? If through the floor you probably have at least 9-10 feet of earth over that sewer line. More than enough for smaller ornamental trees.
Old 05-08-2011, 11:59 PM   #5
Rewards Points: 18
Something like a crabapple, or smaller ornamental tree. The line comes through the foundation wall, front of the house(street side) about 18" off the floor. I have at least 5 1/2 feet of earth over it. Is that enough for a smaller tree?
Old 05-09-2011, 10:43 AM   #6
BIGRED
Rewards Points: 252
I would think so. The trees that have large tap roots that go to great depths to steady the sky portion of themselves are the ones that may sense water inside a pipe and try to break into it. I have an ornamental crab tree just to the side of my sewer grinder pit and it seems like most of the roots are from 3-18 inches under grade. The 4" line from my house is down about 5' below grade, is PVC, and we haven't had any problems.
Old 05-09-2011, 12:12 PM   #7
Rewards Points: 18
Thank you for your help
Help!!! Roto-rooter cable is now stuck in sewer line and won't come out!!! YerDugliness Plumbing 21 01-28-2010 04:04 AM
water sewer line cost housecall Plumbing 1 05-25-2009 07:22 AM
Help! Sanitary Sewer line indigoinmotion Plumbing 1 01-10-2009 11:36 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
sewer main line repar Babar Plumbing 1 01-26-2004 07:39 AM
