Sewer Line Maintenance? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2013, 11:46 PM   #1
sewer line maintenance?
am on city sewer lines
been in this house for 19 years and have never done any maintenance on the main sewer lines
yes i just knocked on wood lol
just wondering ...
any suggestions for anything that can be flushed down toilets to clean up any dried .... ummmm .... dried crud (you know what i mean) that probably exists in them there pipes from house to street?
couldnt find this topic anywhere and thought why not bring it to the DIY people .. this forum is great!
oldernow is offline   Reply With Quote
Old 04-07-2013, 12:05 AM   #2
747
registered
747's Avatar
Rewards Points: 534
best thing to do. CAll a guy with a hydrojetter. He will put the spinner nozzle on it. When he is done the pipe is clean as a whistle. Assuming you have clean out in front yard. power rodding won't scour a pipe. I know of no product to put in to clean a pipe. Only to kill roots.
He will have a bunch of nozzles for it. Like a warthog. Its a badboy. For your application the spinner will be perfect. It will scour the inside of pipe. (i'm not sure what this nozzle is called.) It shoots water through the sides of nozzle while spinning.
My hydrojetter guy has a box of nozzles. The warthog he told me is a 1000 dollar nozzle for stubborn tree roots. On mine its warthog then the spinner.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
oldernow (04-07-2013)
Old 04-07-2013, 07:21 AM   #3
Lord of Slums
Rewards Points: 1,974
Let a sleeping turd lay.
mj12 is offline   Reply With Quote
The Following 4 Users Say Thank You to mj12 For This Useful Post:
ben's plumbing (04-07-2013), COLDIRON (04-07-2013), fetzer85 (04-07-2013), Hardway (04-07-2013)
Old 04-07-2013, 07:38 AM   #4
Rewards Points: 582
if its not broke don't fix it....ben sr ...we don't really do any service on sewer lines ...unless its a customer that has regular problems and they don't want to dig it up...we may water jet it once a yr...
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (04-07-2013), Hardway (04-07-2013), oldernow (04-07-2013)
Old 04-07-2013, 08:51 AM   #5
joed's Avatar
Rewards Points: 12,916
A properly functioning sewer line does not require any maintenance.
The Following 3 Users Say Thank You to joed For This Useful Post:
ben's plumbing (04-07-2013), COLDIRON (04-07-2013), oldernow (04-07-2013)
Old 04-07-2013, 09:50 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 682
I agree with the above comments but if you're loosing sleep over it. Dig out your yellow pages and find a plumber that has a special on sewer inspections. Let them rum a camera down the line. that will tell you if jetting or cleaning is needed.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 04-07-2013, 10:19 AM   #7
Roofmaster
Rewards Points: 2,210
Well this is not for your sewer line, but it makes sense to pour a lobster pot of boiling water through your traps once in a while to clear any build up in them. I also fill my very large kitchen sink and pull the plug once in a while just for the heck of it.
The Following User Says Thank You to jagans For This Useful Post:
Old 04-07-2013, 02:45 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
Like most of the guys are saying if its not broken don't try and fix it, now if you are concerned about possible future problems a camera will do the trick, plumbing systems are designed to be self cleaning, however some lines will tend to accumulate matter mainly grease, such as the kitchen line and the main at ether the second clean out going into the city lateral or at the inlet tee in a septic tank. the only advantage is that if a problem is starting, for example roots, and you have not experienced a back ups at this point you have a head start on the problem, gives you time to plan for a repair weather it be financial or convenience.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-07-2013, 10:50 PM   #9
Always learning...
fetzer85's Avatar
Rewards Points: 262
Any danger to the tubular pvc waste pipes exposing them to boiling hot water? I've heard people say you shouldn't do it but we have pasta about once a week and pour the water down the drain and haven't had any issues.
fetzer85 is offline   Reply With Quote
Old 04-07-2013, 11:18 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Boiling water is the worst thing you can poor down a sink. all it does is soften the grease spreads it further down the line as soon as the water cools the grease hardens. the best thing for preventive maintenance are natural enzymes weekly/monthly treatments they work tested and seen, fantastic results in kitchen drains grease traps septic tanks etc,
The Following User Says Thank You to Javiles For This Useful Post:
plumberinlaw (04-08-2013)
Old 04-08-2013, 04:58 AM   #11
Rewards Points: 352
google bioclean
plumberinlaw is offline   Reply With Quote
Tags
city , maintenance , sewer , toilet
Locating municipal sewer line CplDevilDog Plumbing 2 03-02-2012 11:34 AM
finding a sewer line av-geek Plumbing 16 01-19-2012 06:56 PM
Broken clay(?) sewer line zazz Plumbing 8 02-15-2010 10:12 PM
Help!!! Roto-rooter cable is now stuck in sewer line and won't come out!!! YerDugliness Plumbing 21 01-28-2010 03:04 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
