Sewer Line Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2011, 02:31 PM   #1
Sewer Line Issues
I just had my sewer line checked with a camera. It is about 43 years old and made of clay. The camera showed roots and also some cracks and slightly shifted sections. Do I need to think about replacing this line and if so what should the expected cost be?
kirksullivan54 is offline   Reply With Quote
Old 10-27-2011, 03:09 PM   #2
Msradell's Avatar
Rewards Points: 84
From the information you provided it would be impossible to even give you a guess as to the price. At a minimum someone would need to know the length and depth of the pipe as well as where you live (prices vary greatly by region because of union and other influences on labor costs). As to whether to replace it or not, the decision should depend on if you're having problems or not. If you aren't having drainage problems you could try using some of the chemicals that claim to remove roots from pipes (not a real green solution) and it could be fined for a very long time.
It will not be a cheap project to replace no matter what.
Msradell is offline   Reply With Quote
Old 10-27-2011, 04:19 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 802
As Msradell said...need more info.....
But to give you a starting point...my neighbor down the street...4" clay pipe...buried about 6'...apx 25' from the house to the street.....$7000 total to dig up and replace. This is in Los Angeles......and plumbers are hungry.
ddawg16 is online now   Reply With Quote
Help!!! Roto-rooter cable is now stuck in sewer line and won't come out!!! YerDugliness Plumbing 21 01-28-2010 04:04 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Help! Sanitary Sewer line indigoinmotion Plumbing 1 01-10-2009 11:36 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
sewer main line repar Babar Plumbing 1 01-26-2004 07:39 AM
