Sewer Line With Flat Spots - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2011, 10:46 AM   #1
Sewer line with flat spots
I have a home built in 1959 with occasional backups in the sewer line after heavy use that I cannot clear with a hand held snake; the problem requires industrial clean out; last week the plummer ran a camera down the line and advised he saw a couple of flat spots in the line collecting water. Solution was to dig up and repair flat spots. Any alternatives?
LV DIY is offline   Reply With Quote
Old 12-01-2011, 11:36 AM   #2
jproffer's Avatar
Rewards Points: 714
"Flat spots holding water" would have nothing to do with a drain clogging up.
There has to be something snagging the solids coming through the pipe.....roots breaking thru, etc.
How often do you have to have it "roto-rootered"?
jproffer is offline   Reply With Quote
Old 12-01-2011, 11:32 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
Flat spots or bellies can clog a drain. A soft plug will develop over time. That's why you grade the pipe. There is no way to remove flat spots without excavation and even then there is no real guaranty. Personally, I'd live with it unless you have roots or other issues. It can be an awful spendy fix. You don't mention depth, length or soil type and they have a huge impact on the project cost. Maybe better to cable it every so often as preventative maintenance.
Old 12-05-2011, 01:33 PM   #4
Requires professional attention about every 3 yrs; will be prudent and consider 1 to 2 yr maintenance and hope for best; property is in Las Vegas with hard ground surface. Thanks
Old 12-05-2011, 02:16 PM   #5
Rewards Points: 582
agree with eplumber i have customers we snake out every 1-2 yrs there fine with that as to spending 5000.00 and up...every 3 yrs not to bad if it gets worse over time then think about getting bids....ben
flat patch spots davidhmd Painting 10 11-13-2011 08:32 AM
Main sewer line roots adam1885282 Plumbing 2 02-12-2010 08:32 PM
Help!!! Roto-rooter cable is now stuck in sewer line and won't come out!!! YerDugliness Plumbing 21 01-28-2010 03:04 AM
Help! Sanitary Sewer line indigoinmotion Plumbing 1 01-10-2009 10:36 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
