Old 09-04-2008, 01:49 PM   #1
sewer line back fall
my main sewer line was replaced approximately 7 to 10 years ago. I had it scoped and was informed that there was some water standing in the sewer line from the clean out valve for approximately 15 feet. at the 15 feet point the sewer line flowed normally. I have never had any problems with the line whatso ever. My question is it critical to have the line repaired and if so what must be done.
oakie14 is offline   Reply With Quote
Old 09-04-2008, 03:16 PM   #2
Critical... not likely, but if water is laying in the line, there is the chance that it has settled at a joint or even broken. The problem is probably a bad job of supporting the pipe when the trench was dug and back-filled. The water laying in the line will start impeding the flow, especially solids, and could cause a clog or back-up.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-04-2008, 06:36 PM   #3
Send a message via AIM to Marlin
Leave it be until you start to get problems. It may work for years to come with no problems.
Marlin is offline   Reply With Quote
conversion of portable dishwasher to stationary one grimsbyman Plumbing 14 02-19-2013 08:54 PM
Installing drain line parcially upgrade. jbravo8212 Plumbing 8 02-19-2008 06:12 PM
New sewer line, damp ground tripower Plumbing 2 09-28-2007 03:40 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
sewer main line repar Babar Plumbing 1 01-26-2004 07:39 AM
