Old 10-20-2006, 04:55 AM   #1
Sewer leak below slab. Debris in sand.
I'm a newbie. I might have accidently posted a draft before finishing this post. If so sorry about that.
I have hired a Texas licensed plumber to locate and repair sewer leaks below the slab. Unfortunately I have lost faith in this plumber.
He managed to get his camera stuck in a 3 inch line. Knocked out slab to retreive camera. It was stuck about 3 feet from flange where he went in.
While conducting a test that was leaking at an increasing rate, I saw on the camera monitor that the test plug was being pumped up. The test plug had leaked enough air that water leaked around the test ball causing a false failure in the test. Had I not seen, this I think we would have been knocking another unecessary hole in the slab. After the ball was reseated and pumped up the test was good.
Anyway, on to my question. They are in the process of filling the void in the slab with the sand that was excavated. The copper water lines are in very close proximity of the sewer lines. The sand that was excavated has been tamped back into hole. There appears to be pieces of varying sizes of concrete chips/chunks in the sand. Shouldn't the sand be free of all this debris to reduce the likelyhood of contact with the copper and the possibility of causing a future leak?
Also shouldn't the edges of the slab be swept free of any loose bits of concrete before cementing over the opening?
martin52 is offline   Reply With Quote
Old 10-20-2006, 08:35 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The answer to both questions is yes.
Ron The Plumber is offline   Reply With Quote
Old 10-20-2006, 09:43 AM   #3
Ron,
Thanks for answering my question. I'm going to start another thread regarding this. I welcome your insight.
Ciao
martin52
More On This Topic
Ok. We're outside the house now. We're going to talk about where we tie these to the existing sewer line. And, you remember that we had Arizona Blue State come out and mark the ground on the street to give us an idea of where this sewer line is. Where it... Read More »
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question how do I fix a coolant leak. There are a lot of products that you can add to the coolant which will help seal small leaks in your coolant system. However if... Read More »
Whether your family will be comfortable on your porch depends on whether you've built it at a proper level. A level porch helps furniture stay in place and keeps glasses from sliding off your table onto the ground. You need to know how to find and... Read More »
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
painting sand over sand heather Painting 1 04-03-2007 11:35 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
