Sewer Lateral Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2007, 11:44 AM   #1
Sewer Lateral replacement
The sewer lateral inspection on our new home showed the cast iron pipe under the house had to be replaced. That was done and we have the invoice of the work, when we do our final walk through, is there anything we should look for? I've heard that jacking out the basement can cause problems to the walls and it's an 82 year old house, so it has plaster walls.
jkrodger is offline   Reply With Quote
Old 07-13-2007, 08:26 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
jk,
They shouldn't have had to move your 82-year-old house at all to replace the sewer line.
The only thing that you need to look for is that it meets all local codes and the inspector is happy, and it is functioning well.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-17-2007, 08:52 AM   #3
I know they didn't have to move the house... a friend of ours that had to have the same pipe replaced under their house said they had to use a jack hammer to get through the basement floor to replace parts...they said the force of the jack hammer damaged some of their walls.
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 09:35 PM
Soffits/Fascia replacement - I need some pointers! mcan5276@bellsouth.net Carpentry 1 03-13-2007 10:18 AM
toilet hole Q - not to the sewer Jumper55 Plumbing 1 10-21-2006 10:07 PM
Sewer leak below slab. Debris in sand. martin52 Plumbing 2 10-20-2006 08:43 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
