Sewer Gas Smell When Using Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2009, 04:19 PM   #1
sewer gas smell when using washer
Whenever I use the washing machine and it spins out, I can smell sewer gas coming from the kitchen sink drain. What should I do? Thanks!
karpasi157 is offline   Reply With Quote
Old 08-18-2009, 05:01 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like you may have a vent blocked, restricted or missing.
I say missing because sometimes a waser is added without proper venting.
When your washer pumps out and the vent is blocked it may be sucking the water seal (acting as the vent) of the trap out there by allowing sewer gasses through.
First is to verify that there is a vent and if there is a vent you can snake the vent to see if that corrects the issue. Does the sink drain fine?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
cleaning sewer lines with pressure washer ponch37300 Plumbing 3 07-06-2009 08:26 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Sewer Smell in Bathroom dc11 Plumbing 3 11-07-2008 04:20 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
