Sewer Gas Smell In Basement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2010, 01:18 PM   #1
Rewards Points: 41
Sewer gas smell in basement?
Every so often I get a sewer gas smell in my basement. I never noticed it until I started spending more time down there because I'm working on finishing the space. The house is less than 5 years old.
The smell seems to come every few hours or so and only lasts for a few minutes. It is always noticeable in the same location. I'm not 100% sure but it seems like it is coming from a toliet drain line (pvc) from a first floor bathroom. There is no smell at all in the bathroom itself and the smell occurs when the bathroom is not in use.
I was able to sniff around that bathroom's toliet drain line this morning when I smelled the sewer gas and it seemed like whatever it was was coming from that drain line. It smelled strongest near the fittings where the drain comes into the basement. There are no leaks in the drain line that I can see when using the bathroom upstairs. I've also tried flooding the drain line by dumping a 5 gallon bucket of water down the toilet and the drain pipe was dry everywhere.
I'm looking for possible solutions to this or a way to figure out what is happening on my own. I am going to replace the wax seal on the toliet as a first step. Is there anything else I can do short of calling in a professional to further troubleshoot/solve this issue?
Thanks for any advice!
barlav is offline   Reply With Quote
Old 10-12-2010, 06:56 PM   #2
Rewards Points: 1,910
Make sure there isn't a dry p trap in any nearby floor drains.
Old 10-12-2010, 07:02 PM   #3
Rewards Points: 41
Thanks. There are no floor drains in this basement.
Old 10-12-2010, 07:03 PM   #4
Seasoned DIYer
Rewards Points: 150
Run some water down every drain. This will replenish any traps that may have dried out
HVAC_NW is offline   Reply With Quote
Old 10-12-2010, 07:36 PM   #5
steveel's Avatar
Sewer vent stack blocked?
steveel is offline   Reply With Quote
Old 10-12-2010, 08:48 PM   #6
Are you sure it's sewer gas that you smell? Could it be natural gas or propane?
Pistol Pete is offline   Reply With Quote
Old 10-13-2010, 06:24 AM   #7
Rewards Points: 41
Thanks for the ideas, all fixtures with traps are used multiple times everyday so none of them should be dry. It's definitely sewer gas and not natural gas or propane. I checked the vent stack and all looks clear. I can smell sewer gas coming from it and I looked down it with a flashlight and didn't see any blockages. I didn't flush it or send a hose down it but I may do that also just to make absolutely sure it's not the vent stack.
Old 10-13-2010, 05:30 PM   #8
I've heard of instances where the vent piping was dry assembled and accidentally (I hope) not glued. Can you tell if all the joints are glued?
You may end up needing to do a smoke test. Basically block the vents, put smoke into the main stack and look for leaks.
Old 10-14-2010, 11:51 AM   #9
My guess would be a nail in a vent pipe somewhere. Same thing happened in my house - when they nailed in the baseboard behind the toilet, they drove a nail (with a nailgun) into the vent pipe serving that toilet and cracked it. Since it was all behind the drywall, it couldn't be seen, but you could definitely smell it. I removed the toilet and opened the wall, repaired the broken pipe and patched the wall.
Ishmael is offline   Reply With Quote
Old 10-15-2010, 08:31 AM   #10
Rewards Points: 41
It looks like the wax seal replacement did the trick. I haven't noticed any smells since I replaced it several days ago.
Old 12-02-2010, 02:32 AM   #11
Rewards Points: 956
whats the wax seal for? sorry for the dumb question...
federer is offline   Reply With Quote
Old 12-02-2010, 05:56 AM   #12
Rewards Points: 41
The wax seal is the seal on the bottom of a toilet where it rests on the floor.
Old 12-03-2010, 12:10 AM   #13
Rewards Points: 956
thanks for the reply! isnt that just like a line of caulk? because i got a stinky sewer smell near the bathroom and the bedroom right next to it...
Old 12-03-2010, 05:53 AM   #14
Rewards Points: 41
Here is a photo of a toilet's wax seal.
The Following User Says Thank You to barlav For This Useful Post:
federer (12-03-2010)
Old 12-03-2010, 09:41 AM   #15
Rewards Points: 956
ohh so i need to uninstall it to replace it. thanks!
outside sewer smell susuzie Plumbing 3 09-06-2010 01:23 PM
sewer smell Vitality Plumbing 1 08-19-2010 11:10 PM
No sewer gas smell from open drain JakAHearts Plumbing 9 06-02-2010 02:16 PM
Sewer smell from under sink and adjoining closet, but not from drains? aaronb9 Plumbing 37 09-27-2009 07:42 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 11:35 AM
